Thought I'd have a go at the porous/cracked head modification!
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 26 to 50 of 91
Thread: Thought I'd have a go at the porous/cracked head modification!
  1. #26
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Also not all GM heads have the grub screws on the dizzy end of the oil galleries
    MIGClub Member CortraGTE's Avatar
    Jul 2005
    The South West
    XE Nova
    Quote Originally Posted by Frisco View Post
    If you look at the sectioned head pic, the two virticle(sp?) channels at either end of the highlighted bit are the head bolt holes.
    You can look down them when the head is off and see when to stop.
    A pin punch is made for hitting things into holes
    Nice one cheers mate!
    2 more questions, the bearing lock stuff, once you put it on the pipe does it not get everywhere inside the oil way cause if the pipe is tight does it not just smeer off?
    What length did you cut the pipe too?
    [Edit] I can't read 87mm
  4. #28
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Yes some/most of the thread lock stuff comes off when the bar is pushed in but i didnt put mountains of it on and any that did rub off ended up in the head bolt hole so i just pushed a rag through that with a screwdriver to clean it out.
    Its easy enough with the head off the car. Much better than bining the head anyway!
  5. #29
    MIGWeb User Add_Gee's Avatar
    Mar 2002
    Birmingham
    Vectra B SRi 2.2 Estate
    Quote Originally Posted by CortraGTE View Post
    Once it was inside the head what did you use to tap it in further? A stick?
    lmao lmao very technical
  6. #30
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Quote Originally Posted by Add_Gee View Post
    lmao lmao
    I can just imagine someone poking a bit of twig in the hole. Genius! lmao
  7. #31
    Jul 2005
    The South West
    XE Nova
    Ah yeah I see, forgot they were gonna be there. (Right after being told too! )
    lmao Yup thats me.
  8. #32
    Bishops Stortford
    2 seat 2.2 vxl
    a metal stick...
    http://slindborg.hostei.com/ Gearbox calc, Top speed, compression ratio, engine capacity, 1.4 tuning guide, Wheel offset calculator
    Fixed broken gearbox calc :)
  9. #33
    Jul 2005
    The South West
    XE Nova
    I'd hate to be the person that cuts down the tree it came from.......
  10. #34
    Aug 2002
    Manchester
    Nova Turbo, Civic Type R
    Quote Originally Posted by steveboyslim View Post
    It is also worth renforcing the oil gallery before the head cracks.
    Not all GM/KS heads have an oil gallery plug on the inlet side, so a suitalbe hole may need to be drilled tapped and cleaned.
    Steve
    How would you go about drilling and tapping this extra hole? I assume you need a hole at each side in case you push the tube in too far so you can move it back the other way?
  11. #35
    Mar 2005
    Anglesey<>Manchester
    BMW, Corsa B XE
    If there is only one grub screw you can see the tube down the head bolt hole and watch that it doesn't go too far in, you could also put something down the head bolt hole to stop the tube.
    ah so its a U like shape?
    Benn this pic/explanation may help, its more of a H shape if you looked at the head from above.
    Quote Originally Posted by orsas.com/CarStuff/cav
    • The two head bolt holes A, one of which is used to supply oil (when the head bolt is in palce it will cap off the hole, hence no oil leaks out)
    • The two water paths B, these run the length of the head, but it is this section where the oil passes into the water. You can see the missformation where the weakness occurs (all will become clear).
    • The centre oil gallery C, this runs from the front of the head to the back, it is connected to the cam oil galleries(D) and the headbolt (A) hole to supply oil rising from block to the cam's. The front of this gallery (on the right in the picture) is blocked off by a grub scrw found on the front of the engine, between the two centre exhaust ports.
    • The cam oil galleries D, these run from one end of the head to the other, there is one for each cam. These get oil by it rising up the headbolt, passing into the centre oil gallery, and passing upto them (the paths that leed upto them are caped with crub screws, these can be found under the cam cover).
  12. #36
    Aug 2002
    Manchester
    Done this myself today, had loads of problems finding something to hammer the tube in with but got it to go in eventually. I used steel tube instead of alloy, is this likely to cause a problem?
  13. #37
    Dec 2005
    UK
    Shouldn't be a problem at all. The oil will stop any rust.
  14. #38
    Aug 2004
    Australia
    should be fine
    i also did this to my head so i would never have the problem, my tube went right way through, then you just drill down for the cam feed holes and same for the headbolt holes and away ya go
    Aussie C20XE N13 Pulsar
    putting out 105kW /143hp atws
  15. #39
    Dec 2003
    england
    Gsi16v
    if the head was off would it be a good idea to insert a bolt on the head then insert the sleeve so u know its gone as far as it's meant to.
  16. #40
    Dec 2007
    Spain
    Calibra c20xe
    And, what kind of material did you get into the head? Alluminium alloy, stainless steel,... i have a porous head and i´d like to solve the problem. As i see this, i´ll have two mean problems: find a great material and the exact diameter of it. May i be able to get in with one hand or must it go into more stronger?
    When you refer alloy tube, what kind? Aluminium?
    Thanks a lot.
  17. #41
    Dec 2005
    UK
    It will have to be an interference fit, and I'd imagine you'd need some gentle taps with a hammer to get it in properly if it's a good fit. Any more and you risk damaging something. Any less and you'll get oil seeping around the tube.
  18. #42
    Dec 2007
    Spain
    Calibra c20xe
    Quote Originally Posted by Jack View Post
    Yes, that´s what i thought.
    And about the tube, i suppose that alumiun alloy is better, becouse the head is made of it. But i´d like to read the opinion of those who have done it and are more experienced.
  19. #43
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    So at what point does the head go 'porous' and mix with the oil?
    They're there, in their room.
  20. #44
    Oct 2003
    Glasgow/Oban
    Like it's a hire car
    it doesnt go porous, it cracks beteen the oil and waterways below the tube afaik
  21. #45
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Yeah I know, hence the quotes around porous. That's a thick bit of ally to crack!
  22. #46
    Nov 2005
    leicester
    corsa
    i was thinking about this mod to the heads and couldn't doing this cause oil starvation to the cam? because using a tube will reduce the internal bore of that oil channel!
    i thought about this because i have this mod on my head but the oil is completely blocked off and bypassed outside the head (solid bar mod) and when the car is cold it rattles up top, or even once its been run about and warmed if left to idle it starts to get noisey again like there isn't quiet enough oil getting up.
    i presume the oil channels that feed the cams also feed the lifters?
    Quote Originally Posted by windowlickeruk
    i supose i could lower the caravan lol
  23. #47
    Oct 2006
    channel islands
    Anything
    hi mate quick question between what two cylinders is this gallery? e.g. 2 an 3?
    bit worried as far as i know you can only acces the gallery from the exhaust side as the diagram shows only one grub screw
  24. #48
    Moderator Nobbie's Avatar
    Hemel Hempstead
    with blue lights
    Some heads only have one grub screw, as mentioned above.
  25. #49
    Oct 2006
    channel islands
    Anything
    oh right yes i see jus checking only scanned fru thread must of missed it dopey
  26. #50
    Dec 2007
    Spain
    Calibra c20xe
    Does anyone know what kind of material should be used?
  1. 08-05-2012, 07:11
  2. 07-05-2012, 00:11
  3. 02-05-2012, 14:01
  4. 29-01-2012, 22:45
  5. 30-12-2011, 22:12
  6. 18-12-2011, 10:28
  7. 26-08-2011, 08:53
  8. 16-07-2011, 22:58
  9. 18-05-2011, 20:05
  10. 01-04-2011, 05:39
  11. 07-03-2011, 11:37
  12. 12-11-2010, 11:40
  13. 05-11-2010, 16:55
  14. 10-10-2010, 19:15
  15. &gt;
    Refback This thread
    06-09-2010, 23:07
  16. 04-07-2010, 15:09
  17. 23-05-2010, 19:53
  18. 23-04-2010, 22:38
  19. 13-02-2010, 08:54
  20. 23-11-2009, 14:57
  21. 16-07-2009, 21:05
  22. 29-03-2009, 20:29
  23. 29-03-2009, 14:21
  24. 11-12-2008, 06:40
  25. 10-07-2008, 12:08
  26. 10-07-2008, 11:37
  27. 10-07-2008, 11:21
  28. 22-04-2008, 15:09
  29. 20-04-2008, 21:25
  30. 20-04-2008, 20:22
  31. 20-04-2008, 20:02
  32. 20-04-2008, 17:59
  33. 31-03-2008, 22:29
  34. 31-03-2008, 17:39
  35. 30-03-2008, 20:29
  36. 24-12-2007, 11:03
  37. 15-12-2007, 20:50
  38. 04-12-2007, 22:02
  39. 04-12-2007, 21:19
  40. 04-12-2007, 20:41
  41. 04-12-2007, 20:39
