will this coil fit the above system???
further to my previous question would the coil and module as fitted to motronic m2.5 system work with the 1.6 cavalier dizzy for use with webbers can anyone shed any light on this or my previous question all parts i have are new but just need to know the loom required for which ever question cheers steve
??? still waitin
somebody must know !!
im not sure what parts fit, but using a distributor and module (and hence the advance curve) from a 1.6 8v engine with a single downdraft carb on a 2.0 16v engine with a set of DCOE's really isnt very ideal. The engines differ quite greatly in where they need and want ignition advance and while it may work, it wont be very optimal and it may cause engine damage due to pinking.
carbs should be left in the era they belong in; the EFI system that was fitted IS better than a set of carbs and in my opinion you really wont see any real gains from fitting the carbs, especially with the horrible ignition setup you plan to use
but if u want to go back to the 70's and enjoy pish fuel economy, crap cold starting, and horrible drivability then go right ahead!
HI MATE TO BE HONEST I THINK THE INJECTION SYSTEM IS PANTS COSTS THE EARTH FED UP OF MANAGEMENT ISSUES AND REPLACING SENSORS ETC REGARDING THE DIZZY IN QUESTION ITS BEEN MODIFIED BY H&H DISTRIBUTORS HAS NO POINTS SO THE TIMING IS FINE ON MY LAST CAR THAT I WAS USING AS HILL CLIMBER WAS PRODUCING 211 BHP ON 45s HOWEVER SINCE DISMANTLING HAVE LOST THIS SECTION OF LOOM SO REQUIRE IDEA'S TO WHAT WENT WHERE TO START FROM SCRATCH AND MAKE UP A REPLACEMENT TO BE HONEST ALL THIS MODERN STUFF IS SHYTE ALL IT NEEDS IS STANDARD MODULE COIL AND AWAY YOU GO NONE OF THE OTHER JUNK THAT IS PROGRAMMED TO RIP YOU OFF AT RANDOM !!!SO I THINK PERSONALLY OLD IS BETTER LASTS LONGER TOO !! CHEERS
Yes to crap fuel econemy and cold starting but if tuned properly the carbs are completely fine to drive in normal conditions.
As for no real gains id say 20-30bhp increase for the price is pretty good if your willing to pay for the fuel
Do you still need to know the part number of the coil amp? if so i can check for you on friday..
Hi Matey Got It Sorted Now Cheers Steve
what leads did you use in the end mine are a bit of a temporary measure work fine but are not perfect. I want some with the long necks for the plugholes on the xe but i dont know what to look for??
leads
hi mate sorry for the late reply the first set i dismantled and made a set up to suit then sent them away and had custom 12mm racing leads made fantastic worth every penny cost £50.00 from a guy on cheese-bay !! it's all they make and sell but they are ace quality items i will send you there email shortly ,been away for a bit due to death of pc !!!
