have recently replaced the rad for a c20xe one which is bigger as my stock rad was leaking.
now it seems that water level drops 1-2cm every now and then. almost every 100km.
dont know where the coolant goes.
there is no mayo in the coolant tank and no mayo rusty colour on the oil cap on the rocker cover.
i know there are leaks around the engine such as the dizzy (still leaking after 4 o'ring replacements), around the rocker cover, and i think there might be oil around the head but i am not sure if it's leaking from there or it just gets gathered from the rocker cover leaks.
concerning pressure in the coolant tank, there is if you try to open the cap when the car is warm. isnt that normal? i mean water evaporates at 82 celcius + therefore when coolant temps are almost 90 - 95 degrees there should be pressure in the system. how much time after should i open the cap to see if there is pressure in it?
as soon as i travel 60km and i turn of the car, i pop open the bonnet and i can hear bubbling near the area of the turbo and the rocker cover. what is it? is it normal? i also see some water being returned from the turbo return pipe into the coolant tank and it comes in splashes (like when I CUM)![]()
is that normal?
other than the above, the car smokes a little bit only in the morning and there is clear water with some carbon dust that is splashed as soon as i fire it up. i think this is due to the exhaust being cold in the morning because it's stainless steel?
any ideas what else to test to see where the coolant goes? i am not worried as much about the coolant as i am about a fecked head gasket. i just want to know how i can find out about if the head gasket is gone.
cheers![]()
Tio
