Fitting twin webber 40's...
Results 1 to 20 of 20
Thread: Fitting twin webber 40's...
    May 2007
    Just got hold of some twin 40's for my calibra 8v (C20NE)... its coming with inlet manifold.
    Is this all i'll need to get it fitted, or am i gunna need anything else???
    Linkage kit, FPR, filters???
    Cheers, Mark
    Jan 2007
    Co. Meath, Ireland
    Mk2 Cav LET
    That and something to control the spark.
    Dizzy or a coilpack
    Mar 2004
    Stoke
    An Alfa
    Need a different ignition setup, off a older carb engine.
    Dec 2005
    walsall
    corsa c20let
    1.6 carb engines are normaly a good donor for the dizzy, also you need a mechanical fuel pump or if your going to use the normal pump then you will need an inline fpr to control the fuel pressure going to the carbs,
    May 2007
    Cheers for the replies...
    ... which models with a 1.6 would be decent donor for the dizzy? and also models for the ignition setup??
    and which is better to use, mech fuel pump or inline FPR?? Whats diff between inline FPR and just a normal FPR (or isnt there??)
    Thanks again.
    ... also, how vital are the filters... as i just dont think theres gunna be enough space in the bay????
    Jan 2007
    Co. Meath, Ireland
    Mk2 Cav LET
    Filters are absolutely vital, if space is a problem then filter socks will do.
    A diet of grit will kill the engine rather quickly!
    An electric pump and a filter king fpr is the best route.
    I dont think the 1.6 dizzy fits on the 2.0 8v engine
    May 2007
    i suppose not... is it vital i change the dizzy then?
    Mar 2004
    Stoke
    An Alfa
    Yeah, as an injection dizzy doesn't have a mechanical timing advance system, so you wont get the ignition advancing through the revs.
    I wouldn't say filters are vital tbh.
    Recommended, but not do or die.
    Jul 2005
    middlesbrough
    cali turbo nova
    i used to love lookin at my shiny trumpets. filters arent that vital
    Awaiting Email Confirmation
    Jun 2002
    filterless probably won't kill it quick. If you're using it as a track car, I wouldn't bother. If it's a rally car then the flying dung potential is higher obviously. Road wise, it's probably an idea, but barring bad luck it'll get by. NEs are only about £7 if it does eat a vole.
    Aug 2007
    hampshire
    corsa b 1.6 8v carbs
    id say the filters r pretty essential for the road especially in the winter, probably get away wi it on a track, ive got twin 40's with k&n filters on them, corigated type, they r quite long, try a single domed foam filter that covers all 4 trumpets as it wont stick too far back toward the bulkhead, i think piper x make em?
    Jun 2004
    Southampton
    Cav Calibre, Beetle
    Quote Originally Posted by nova2l16v View Post
    Really not a good idea to drop from a couple of bar to ~3psi, if the regulator fails you're going to be feeding fuel at ~40psi ore whatever straight to the carbs, if you don't get plenty of borewash and kill it, you're going to start some nice fires... Or both
    Saw it happen to a 205 on 45's, not nice.
    Much better to get a low pressure fuel pump too.
    Slammed, cammed, -120mm 106 GTi
    Fast road spec, twin 40'd 1975 Beetle
    Dead, rotten, forgotten MK2 Cavalier Calibre
    May 2007
    Thanks for all the replies... need abit help on another thing now... after getting round to cleaning up the carbs and just giving them a check over, its becoming more apparent that the lad thats sold them to me obviously worked in IKEA... AM MISSING SH*T LOADS OF BITS! (Guess thats eBay for you). Anyways, does anyone know of any companies or anyone on MIG that sells carb componants? Cheers
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    I used to use this guy on ebay quite a lot (It's an ebay shop rather than an idividual). He's really very helpful. > http://stores.ebay.co.uk/FAST-ROAD-CARS
    May 2007
    Nice one!! i've called him and this guy was very helpful and has agreed to help me out.
    Would really recommend him to anyone whos either looking for carbs componants/accessories or just general advice, he was more than willing to offer it... TOP BLOKE.
    Cheers for all your help on this one lads, much appreciated.
    Mark
    Jan 2007
    Co. Meath, Ireland
    Mk2 Cav LET
    Yup he is by far the best weber dealer around
    Jan 2008
    N.Ireland
    Was reading and as im thinking of fitting webbers to my 2.0 8v but someone says the 1.6 dizzy wont fit a 2.0 8v does it? If not which one does and is it a straight swap with a c20ne. cheers
    Jan 2008
    N.Ireland
    Can anyone help??
    Jan 2007
    Co. Meath, Ireland
    Mk2 Cav LET
    I dont think there is a straight fit dizzy for the NE/SEH. You can fit the cam box off an earlier 1.8 or 1.6 8v and use the dizzy from that or go the ignition management route.
    Jan 2008
    N.Ireland
    ok so i need to use the cam box cam and dizzy from a 1.8 or a 1.6 or does the cam from the ne go into the cam box from a 1.8 or 1.6? cheers
