hey guys, i have a C20NE and a 20SEH engine.
i plan to use cam pistons and ecu from the seh onto the NE since the NE is already stripped right down and cleaned.
the seh ran a 'flap' type afm whereas the NE has a different type of afm which looks far less restrictive, but in having to use the SEH loom and ecu, can i wire the afm plug to fit the ne afm, and it work fine?
or can i just use the NE loom on the seh ecu???
cheers
cheers
