Results 1 to 22 of 22
Thread: 1.7 turbo diesel isuzu swap guide for corsa/nova
    Aug 2005
    Newcastle Upon Tyne
    corsa B 1.7 turbo D
    Arrow 1.7 turbo diesel isuzu swap guide for corsa/nova
    Right then, Ive just done another engine conversion on a corsa changing the engine from a 1.7 diesel to a 1.7 turbo diesel. I thought since people keep asking how to do do it and what parts you need I thought I would put a general guide with a couple of pictures to help.
    Parts needed: 1.5 turbo diesel front pipe from a corsa if you have a corsa or a 1.5 turbo diesel front pipe from a nova if you have a nova. (The rest of your existing exhaust is the same so no need to swap or alter those bits)
    A suitable intercooler
    A selection of boost hoses
    I would also recommend:
    A new timing belt,
    Oil
    Oil filter
    fuel fillter
    air fliter
    3 piece clutch
    You use pretty much everything from the original 1.7 diesel engine including:
    Alternator
    Starter
    Flywheel
    Clutch
    Gearbox
    engine mounts
    driveshafts
    You need to alter the block casing next to the starter as the turbo diesel engine differs slightly in this area as it had a bigger gearbox bolted to it. (See pics)
    The original corsa engine already has this cut out as standard like this,
    This picture shows where you need to cut the block to suit.
    Basically it needs grinding down flat, something like this,
    This is a very necessary mod so the corsa rear gearbox mount and gear linkage clears the box. If you dont do this you cant bolt the rear mount on or be able to select any gears. You need to fit your corsa starter, flywheel, clutch and gearbox which all bolt straight on.
    You must also swap the the cavy engine mount for the corsa mount otherwise the engine wont sit right (See pic for the differences)
    The bolt holes line up perfect so its just a straight swap
    I would recommend that you swap the inlet manifold with that from a corsa or astra turbo diesel as the cavy inlet manifold is much bigger and leaves very little room to be able to access things like the fuel pump and oil filter. Also the corsa and astra manifolds look much better and more modern.
    You also retain all of your original water hoses, just swap them over onto the new engine. You do have to shorten the length of small hoses which you will find that go from the oil cooler as the thermostat housing is a slightly different shape but makes no difference otherwise. Also dont forget to swap the alternator over aswell.
    Other than that all you really need to do is alter the boost hoses to suit your intercooler. I personally used the cavy intercooler and redirected the hoses to the passenger inner wing just below the headlight and fitted a cone in the corner of the bumper. (see pic)
    I will update this soon as I have probably forgotten a couple of very minor things but thats basically it. Its pretty much a straight swap once you have swapped the corsa bits over and grinded the block. If anyone has anything to add feel free to do so. I hold no responsibility for anyone who gets its wrong, im just trying to help people by offering what I found myself when I did my own car.
    EDIT: Forgot to mention earlier that you need to fit the smaller corsa diesel oil fliter, not the cavy oil filter as they are bigger and it will foul the starter.
    Corsa B 1.7 turbo diesel
    MK4 Escort 1.8 16valve zetec turbo
    Jun 2004
    Twisk, Holland
    '97ComboD '93NovaTD
    Nice write-up, any more pics (engine bay, intercooler etc.) ?
    Aug 2005
    Newcastle Upon Tyne
    corsa B 1.7 turbo D
    Quote Originally Posted by DutchNovaDiesel View Post
    This is the only other picture I have at the minute.
    I have since changed the inlet manifold for an astra manifold when I did the white ring mod to the fuel pump and turned the max fuel screw up. I have added a boost gauge and a bleed valve so she is now running 20 psi of boost. I have also done away with the cat and middle box and I welded a straight through pipe in there place. I have just bought a sierra cosworth intercooler which im going to fit into the front bumper just under the number plate. The only problem I have is that I fitted PAS to the corsa when I fitted the engine so the fluid resivour is now in the way of where I would have put a K&N type air filter and also the PAS pump gets in the way of boost hoses running along that part of the engine bay to my new cooler. Still it gives the saxo vtr boys a run for there money, lol. When Ive got the new cooler fitted im going to fit a new clutch and then get it rolling roaded to see what shes putting out. What do you reckon to maybe an f28 6 speed gearbox conversion Dutchnova? If you can use a standard cavy box why not an f28?
    Jun 2004
    Twisk, Holland
    '97ComboD '93NovaTD
    Quote Originally Posted by macturbo View Post
    Because the F16 and F18 use a 200mm clutch with a 24 teeth spline, and the F28 uses a 228mm clutch with a 14 teeth spline.
    That would need a custom clutch, or a heavily modified (or custom) flywheel, and ratio wise it's not worth it.
    Corsa gear ratios: http://oege.ie.hva.nl/~jelsma02/Over...0Corsa%20B.jpg
    Calibra gear ratios:http://i12.tinypic.com/48r46ea.jpg
    If you want to reach a higher top speed, an F13WR 3.35 or 3.55 will get you there. (late Corsa B TD...haven't seen one yet)
    Or an F16WR 3.55 or F18WR 3.57 if you want to go the conversion route
    (all of these will give a higher top speed then the F28 in 6th)
    Point of advise: don't try to go for top speed with you're TD, that's when they get hot and that's what kills it
    (maybe one run to see what it does, but don't do it on a regular basis)
    Just found this: http://img183.imageshack.us/img183/2165/10ks9.jpg (portugese corsa)
    May 2004
    Oxfordshire
    Skoda Fabia VRS 130PD
    This is all great stuff. I have a year 2000 Corsa 1.7D and have been thinking of the same conversion. If I buy an Astra 1.7TD of the same vintage would I be able to just swap the engine and box over without mods except the exhaust and maybe the intercooler? Maybe I could cut the down pipes and just swap them over? And would the rad/intercooler from the Astra fit the Corsa?
    May 2004
    Oxfordshire
    No thoughts anyone? And is there anyone in the Oxford area who could do it for me if I get the bits?
    Aug 2005
    Newcastle Upon Tyne
    corsa B 1.7 turbo D
    Jonathan Scott: Fitting the astra isuzu engine is exactly the same as fitting the cavy or vectra engine, you still need to alter the block slightly and fit your ancillaries etc to the new engine.
    Dutchnovadiesel: Here are some more of the pics of my engine bay you asked for the other week.
    Sep 2009
    chippenham
    '95 corsa 1.5td 4dr
    Re: 1.7 turbo diesel isuzu swap guide for corsa/nova
    That's interesting to see what you have done with the intercooler Macturbo- I have 1.5 Isuzu engined corsa and was thinking of doing that! I've even got a 1.7 intercooler standing by, for when I finally get motivated.
    Gimme that Fackin' shootah!
    Apr 2007
    northern ireland
    did the 17d corsas all come with the isuzu straight derv engine? hoping to get one soon and just want to check before i go looking
    thanks
    Aug 2005
    Newcastle Upon Tyne
    corsa B 1.7 turbo D
    They do a 1.5, 1.5td and a 1.7 diesel engine for the corsa B.
    Apr 2007
    northern ireland
    yeah im looking to know if the 17D's are all isuzu or was a gm lump fitted aswell. hope to have one coming tomorow.
    Aug 2005
    Newcastle Upon Tyne
    corsa B 1.7 turbo D
    Heres a couple of pics of the engine bay for you.
    If I did another conversion I would use a non turbo manifold so you wpuldnt end up with the 2 top holes in the turbo manifold as shown in the pics.
    Sadly as far as im aware the car has been scrapped
    I sold it nearly 2 years ago.
    Guy I sold it onto had the car painted black aswell.
    The enquiry is complete
    The vehicle details for P567 LRE are:
    Date of Liability 01 12 2009
    Date of First Registration 01 08 1996
    Year of Manufacture 1996
    Cylinder Capacity (cc) 1686CC
    CO2 Emissions Not Available
    Fuel Type Heavy Oil
    Export Marker Not Applicable
    Vehicle Status Unlicensed
    Vehicle Colour BLACK
    Vehicle Type Approval
    Vehicle Excise Duty Rate for vehicle
    6 Months Rate £104.50
    12 Months Rate £190.00
    Apr 2007
    northern ireland
    were did you get the check done mac?
    would be nice to know if a few of my old cars are on the road
    Aug 2005
    Newcastle Upon Tyne
    corsa B 1.7 turbo D
    DVLA Vehicle Licensing Online | Home
    click on vehicle enquires
    Apr 2007
    northern ireland
    ive started into striping everything of the 17d corsa engine today so moving forward. will have to take some pics maybe tomorrow and get a project thread on the go.
    whats the black plastic box ontop of the inlet on the 17d corsa engine?
    Apr 2007
    northern ireland
    if using the corsa 17d alternator do i use the cav td belt or the corsa 17d. do i still use the td powersteering pump
    Jun 2004
    Twisk, Holland
    '97ComboD '93NovaTD
    The small black box is a resonator(or airfilter housing on older models), to reduce intake noises (nova's have a bunch of them).
    Belts are the same (12,5x925).
    Have you got the two engines next to eachother, at a guess i'd say the ps-pumps are the same.
    Apr 2007
    northern ireland
    thanks dutchnova. cant wait to get it finished. will be up at it tomorrow doing some more work so will take pics of the cavy and corsa and get a project thread started
    Apr 2007
    northern ireland
    when you have the cone filter on what have you done with the breather pipe? i can see it pointing down behind the head, have you done anything with it or just left it loose?
    Aug 2005
    Newcastle Upon Tyne
    corsa B 1.7 turbo D
    You can leave it loose but it might leak a slight amount of oil over time or buy 1 of these for it mate:
    CHROME BREATHER / EMMISSION VALVE FILTER - UNIVERSAL on eBay (end time 10-Apr-10 15:56:30 BST)
    Nov 2008
    Luton
    Smokey Saloon
    old thread bump , but did any do this ?
    any problems along the way ?
    Apr 2011
    1998 Corsa B 1.7d 3 door
    anyone have luck with this?
    I have a 1.7d and a 1.7td engine, need to know a bit more about doing the actual engine change.
    Is it all plug and play with the new engine or is there like a new ecu needed?
    only parts i need are an intercooler and air filters. I have a load of pics if anyone can help me.
    thanks
