Have you looked at the correct number??
dream project lotus carlton lump in a viva on ms and 2.1 bar!
Yep, thats the number where the engine number should be,
Out of all the XE engines I have had, thats the only one that has me wondering why its different
The engine in my Silver Corsa is number 14083624
Where do you find this number?? I have an engine , No idea what it came out of but would like to find out.
Engine has HH3 and R90 400 010 cast into it...
Any ideas?
Cheers.
you should find your engine number on the block where the gearbox bolts to its about a 10mm plate beside the dipstick
Thanks..
My number is 14096068
Any idea what it's out of?
14000091 - Braintree's new engine - confirmed hi-spec.
14000099 - MattJ new block
14000100 - Corsa c20xe
14000111 - Gaz's new block from GTE 16v
14000471 - Bicco`s Cally T (let)
14000633 - Astraderv (surely too low for an Astra GSi?)
14001007 - Braintree
14001154 - Mick Vxr C20let..Rayleigh,Essex
14001537 - Davey J Astra GTE 16v
14001648 - In Dallara F398 F3 Monoposto race car. Standard road spec.
14001672 - Jhonno
14001922 - Colonel K's xe, sat in garage... from purple GTE scrapper Im chuffed!
14002106 - an old piece of detonated **** + knackered coscast
14002346 - gillys redtop mk4 astra engine (dizzy 89 on cam cap )
14002870 - jamesy(30/09/88)freg gte engine
14003804 - EPC Listed head change
14005031 - Cavvysri`s next one
14005048 - Early type crank cut off.
14005234 - geogsi's 88. GSi 16V
14005956 - scottc1088's 20xe
14006525 - benhelens 20XE
14006629 - unknown bottom end,coscast head.p16vlv.
14007197 - Respect's Kadett E GSI16
14007931 - It's the one in Evil's Mk1 GTE....
14009172 - odders (car made october 1988, uncommonly high engine number)
14009715 - PhilAstraSport's XE
14011167 - non coscast replacement engine in 1990 gte
14011339 - Jason's Coscast XE Going in a Mk1 Astra
14011910 - Rusty - from GTE 16v of unknown origin, ended up in Nova
14012333 - MikeT's 20XE from GTE reg 20/3/89 (still in bits!)
14012554 - Cavalier-c20let, C20LET bought from Ebay as bare block
14013125 - Tommy M`s C20 LET removed from 1994 Cavalier Turbo
14013822 - TrickyB
14014227 - Cam cover change
14016377 - Nov 1995 (96MY) C20LET in Cally T (the_fbi's orig engine)
14017848 - 1996 C20LET in a Cally LE ( MartG )
14017914 - cmac86 - C20LET with Coscast Head & full forged rebuild in 97 Ph2 Astra GSI
14017978 - C20LET - DOUGAL (1996 LET)
14018303 - 20XE coverted to c20xe in 5chaap2k's Corsa
14018318 - GM Head - GTE Valver F reg
14018652 - Ed's GTE 16v engine. G-reg (although in a J-reg shell) Coscast Head, no Lambda
14019260 - Sid's COSCAST 20XE from Astra GTE F/G reg
14020914 - Brett's GTE 16v (June 1989)
14021158 - C20XE - ste_sa (current block)
14021695 - Orange Peel (F reg GTE Coscast)
14024413 - Kread Cav GSInow in scrap yard
14024492 - robbie dee's 20xe zzr1100 bike carbs in locost 7
14025548 - 20XEJ Mark '97 Shelled F- reg GTE
14029472 - Puberts Cav GSi 2000
14030368 - maniac8v - 20XEJ *Just got mine im turning it into a LET*
14033230 - VEGA (GM head) sold with car
14033974 - astra gte16v 1989 coscast head
14034338 - GreyDJ XEJ now 2.1 not in car ATM
14034648 - Joekonts old GSI G plate
14034761 - Kread new cav gsi Reg. Oct 89
14034867 - Krugers Cav Gsi G plate, 2.0XEJ
14035104 - daddy cav's cav gsi '90
14035411 - Gaz's GSI cav 1989
14036987 - badassnows 20xe throttle bodied corsa b
14037172 - C3MKY Cavalier GSi2000 2wd 1989
14038976 - Simon XE now in Corsa
14039046 - Jason's Astra GTE 16v G-Reg
14040052 - Super__dan (std 1990)
14040525 - Brian Stirrup Astra Cabriolet (Donar car Astra GTE 30/3/90) Currently a bare block brought by A2 (Andy)
14042299 - DeimonNG 20XEJ - Coswort head Cav GSi 1990
14041654 - Ben_Copeland Cav GSI 1990
14043603 - Palimanto's out a Cav GSI 90
14044860 - Cavvysri`s first one
14044967 - Joy`s Supercharged XEJ
14045501 - Dazzy130 mk2 cav (1990 astra)
14046036 - Hatchets 20XEJ Corsa(1990 astra)
14048637 - geogsi's 2nd, '89, 152K miles, great condition!
14050667 - Darrenm's Cav GSi2000 4x4 1989 G reg
14051000 - Rik C20XE from Astra GTE. Marked 89
14052450 - C20XEJ - ste_sa (had 89 on cam caps etc)
14052548 - gillys redtop cav (dizzy 90 on cam caps)
14054271 - Damo B
14055336 - Kieran's (GM head)
14055549 - SPARKYMARKY
14056011 - C3MKY Cavalier GSi2000 4x4 1990
14057531 - C20XE - jamie f Cav GSi
14058908 - djivesp's opel tigra xe (from 1990 calibra supposedly)
14059983 - dethstar's 1990 gte 16v
14065339 - H20GTE - Astray's 1991 H-reg Astra GTE <--
14063356 - C3MKY - Now in Kit Car
14063819 - Pete_58 Unknown origin (belived to be the bottom end from Garys yellow Astra GTE) Going in my Nova 1992 K plate
14064043 - ASTRAGSI1816V - recon'd engine
14064580 - LiamS Coscast GTE 1991 J Reg
14064931 - Ed GM head 1990 GTE
14065318 - astraliam astra gte H plate
14065718 - nick 1992 j reg GTE
14067431 - Pete_58 Astra GTE 1991 H plate broken and scrapped, engine still in bits in my garage!
14067801 - GTE16V's GTE 1991 H plate
14067920 - MattJ Coscast MK2 1991 H reg
14070549 - Gordo C20XE in '91 Opel Calibra - in New Zealand.
14070809 - Joys 93 Cav (91 GSi 4x4 engine)
14070830 - J4LDO currently in corsa B was calibra
14071211 - danny_bellis (C20XE wtg rebuild + transplant into Nova [unknown donor, came from Nova Conversion done by Courtenay])
14073670 - Owens Cav Gsi
14074759 - Batfink 1991 H reg GTE
14075428 - Debeerd's Kadett 200is 20XE
14075526 - Debeerd's Corsa B 20XE
14075969 - SR Stealths F Reg Nova
14076152 - Orbital GM Head
14077197 - Joekonts Astra GTE H plate
14077417 - dathers,Nova GTE C20XE,came from a 92 cav GSi
14077506 - Astra Dan - My H plate GTE 16v
14077578 - Terry's 1990 H Plate GTE 16V
14079150 - J100RSA's Corsa previously from 1991 cav gsi
14083682 - cavalier gsi 2000 2wd 1991
14084324 - cavalier gsi 2000 2wd 1990
14087743 - benn's xe now in the nova <<<<
14090383 - Jason Gemson 2.0 16V conversion
14091003- 1988 nova (novaboy_20)
14093653 - superfastscottie cav gsi j-reg
14095879 - redliner J reg GTE 16v
14096011 - eggy.navy 20xe now going into a corsa b just waiting for funds to get mounts
14096079 - Y444TES now in Corsa GSi
14105328 - Bishy15 20XE in Astravan?
14105962 - GavCorsa1.6 - 20xe removed from corsa, unknown origin
14108022 - Brett XE from J reg Astra GSi - Block clearly stamped 20XE not C20XE
14108025 - Matt2345
14108036 - Autosparks astra gsi with 132k on the clock and still going strong
14110204 - jack from Australia's smahed calibra thats getting a rebuild! then engine will go in my original calibra, dono wat number means tho
14110533 - steve 20XE corsa sport, dizzy engine, was told it came from a calibra??
14112482 - MikeT 20XE from Astra GSI going in my Astra CD
14113261 - Astra GSI 16v Came with Dizzy and 3bar fuel reg-fastcarmaniac
14119602 - TiMiX Astra GSI J Reg
14120060 - Archie Frew J85 HPN '91 Astra GSI (Removed by Me), Now in 20XE Corsa, Partially Rebuilt July 2010
14120116 - gsi j reg
14120415 - Tomk - 03/03/1992 astra gsi
14123114 - LEE69
14125224 - Baz116, C20XE Calibra registered feb '94
14126279 - DarrynGSi
14128448 - Change of short motor exchange
14129374 - chris82a nova 16v
14137011 - Head change/Exhaust cam/big end shells (dis?)
14137550 - Joy`s C20 XE Turbo
14140154 - originally in a '92 Cav GSi, now QED'd, SBD'd and fitted in a Westfield
14142001 - Originally Astra GTE but now XE Tigra - Oakey22
14147856 - Brett - 92' Calibra
14151969 - Dazzy130 1992 Cav SRi
14155058 - BROOMY ex Calibra dispac 92 now 97 Corsa B
14161514 - denno's xe from cav now in corsa
14163206 - From H reg Astra GTE (GM head, i think?)
14163347 - 93 Calibra with DIS and M2.8 Ignition
14164599 - Sert`s '94 calibra
14167691 - Cengiz's 93 Calibra XE M2.8 fully original
14172443 - T1000's 93 Calibra XE
14173420 - Piston change
14175423 - GreyDJ 93 Cavalier SRi Luton built
14176930 - BrianE Brian's '94 Caterham HPC (in the States)
14177139 - Stevey_n1 Astra (was from Calibra 94)
14177220 - Bicco`s Old Cav SRi 16v 93"
14177240 - Cavalier-c20let, C20XE bought from scooby-killer from 93 cally, converted to turbo now
14177271 - tony sri 93 Cav SRi 16V
14177280 - LLTN Nova xe-From a '93 Calibra 16v(dispak)
14178906 - Brett - 1994 Calibra
14180973 - P.S.Guy Came out of a Calibra, Now in my nova !!!
14181192 - In Dallara F397 Monoposto race car. Standard road spec.
14181977 - jack-offs 94 calibra
14182154 - The Guru C20XE with DIS from Calibra now in Corsa B
14182248 - Rudd86 out of a calibra converted to LET for a cav turbo
14184266 - Kilvos XE, DIS, 93 GSI 2.0
14184621 - Hersch's Astra 200iE 16v
14185463 - Nickyboys XE, latest so far
14192384 - lukguns's Calibra 95'' with C20XE(Cosworth) brazilian edition
14195117 - Last ever XE engine built in Jan 1998
can any1 tell me wat its out of and the year cheers 14024492
If you look through the numbers above it slots in around 89-90 so could be out of either a mk2 astra GTe or a Mk3 cav.
There is no real way of telling just by the engine number.
Vaux could prob tell you
Did cavs have 20XEJs though? Something about cats and 4x4s seems to ring a bell now I think about it.
Thanks frisco im trying to find a reg to order parts abit easier with.
14001672 - Jhonno
14013822 - TrickyB
14022443 - Vinci's MK2 Astra hollow sleeved KS700 head
14054271 - Damo B
14108025 - Matt2345
14123114 - LEE69
Mines c20xe 14039846 gm head astra gte?
From THE Netherlands,
14081479 cd-design's '86 MkII Astra gte 16v, Coscast, M2.5, EDS 7800rpm, E85 at 3.5bar. Originally from '91 Calibra 2.0 16v
I've taken the freedom to continue the thread on the Dutch Opel forums.
Opelforum • Toon onderwerp - 2 liter 16 klepper motor nummers, welke heb jij??
For those in the Netherlands who are not great with English language I have put some translations in to describe the changes applied by GM. I've also printed them in BOLD font.
Now I also have a question, my English isn't perfect either you see...What does this mean exactly?
Short motor- is basically an exchange bottom end bought without cylinder head or ancilliarys (manifolds etc)
My spare block has a diff engine no written. It's on the same place where the original should be but it is G4 043 bx 84261 and I was told that when the engine was reconditioned they changed it ... can't see why tbh.
Anyone has any idea about it?
When It comes to motorsport its what you build not what you buy
Re: 20XE engine codes- what number is yours?
14001672 - Jhonno
14013822 - TrickyB
14054271 - Damo B
14071043 - opelmantagsi - in New Zealand.
14071858 - opelmantagsi - in New Zealand.
14091393 - opelmantagsi completely rebuilt and fitted with Coscast head and side drafts then slid into a Manta located in New Zealand
14097012 - opelmantagsi - undergoing complete rebuild, fitted with Coscast head as a SPARE for my Manta located in New Zealand
14108025 - Matt2345
14123114 - LEE69
14001672 - Jhonno
14013822 - TrickyB
14054271 - Damo B
14090182 - Opel Manta GTE 16 Valve Conversion on bike carbs.think the engine was out of a Cav GSI.
14108025 - Matt2345
14123114 - LEE69
14001672 - Jhonno
14005824 - vectra640 mk3 Astra LET convertible
14013822 - TrickyB
14054271 - Damo B
14108025 - Matt2345
14123114 - LEE69
Vectra B GSi Turbo Coming Soon ...........
I WONDER HOW MANY PEOPLE LOOK AT MY VISITOR PAGE JUST TO OGGLE MY MRS TITS HA HA HA
14001672 - Jhonno
14013822 - TrickyB
14054271 - Damo B
14069490- 1990 calibra 16v H reg gm head
14108025 - Matt2345
14123114 - LEE69
14169137- unknown doner/corsa
14001672 - Jhonno
14012814 - My (Burlers') 20XE, rebuilt in 2006, unknown donor, now in a Westfield, GM head, GSXR TBs
14013822 - TrickyB
14054271 - Damo B
14108025 - Matt2345
14123114 - LEE69
Mine is 14081550 - Now in a Dax Rush kit car, no idea what it's from in case anyone can help?
Seems to fit amongst the Cav GSIs on the list (if you'd bothered to put it in).
14001672 - Jhonno
14013822 - TrickyB
14038614- g reg astra Gte now in a nova
14054271 - Damo B
14108025 - Matt2345
14123114 - LEE69
14195117 - Last ever XE engine built in Jan 1998[/QUOTE]
I´m from Brazil My C20XE was removed from a Vectra A GSi 94.
block Number is 14183597 today that block is running in a Corsa B GSI.
Corsa GSI 1.6 16v Turbo @ 1,2 bar = 260whp.
14046152 from a H reg Astra GTE Champion going into my 1997 Corsa B
