Results 1 to 10 of 10
Thread: AFR lambda sensor colors???
    Apr 2005
    Teeside
    Corsa CLET/Evo8FQ330
    just wondering if any1 knows wich wire out of the 3 on a c20let engine is the 1 that afr joins to and reads off
    Apr 2005
    Teeside
    Apr 2002
    Southwest
    Like its stolen
    Easy to check with a voltmeter, cant remember off hand.
    Will check at weekend when im next near a LET if you havent found out by then
    Apr 2005
    Teeside
    aye please m8 as says not recommended using volt meter on oxgen sensor or afr gauge lol
    Apr 2002
    Southwest
    Like its stolen
    Ok mate, will do at the weekend, if it looks like ive forgotten you send me a PM on www.vauxsport.com and remind me, as ive got a lousy memory.
    Northeast Kent
    theres a 3 pin connector on the bulkhead, on the side that goes down to the sensor itself you got 2 white wires and 1 black. mine is tapped into the black. which translates to the brown with blue trace on the other half (the car loom side) of the connector
    i only know this as i intend to disconnect it. its just useless flashing lights when used with the stock lambda sensor. the sensor only reads voltages for close to "stoich", and not the voltages for 12.whatever AFR on boost. so basically the guage wont show you anything useful regards the safety of your engine.
    Mar 2003
    Ayrshire, Scotland
    Astra Coupe Turbo P1
    my narrow band gague was good, as i knew i had a fuel problem on boost as it wasn't reading full rich just over stoich on boost where as before it was reading full rich. so they do work in some sense
    Apr 2002
    Southwest
    Like its stolen
    Quote Originally Posted by incentive View Post
    Thats what happened on my engine, although by then it had already melted.
    Its kind of like Ive got this great speed camera detector, its called the postman, if I go past a camera he tells me lmao
    Aug 2006
    huntingdon
    E46M3/GSXR750/RWD SCOOB
    Quote Originally Posted by chip View Post
    sorry to but in but that just made me laugh soooo muchlmao lmao nice one
    Mar 2003
    Ayrshire, Scotland
    well all i can say is it saved mine.
