cosworth hybrid turbo onto cav turbo engine
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 31
Thread: cosworth hybrid turbo onto cav turbo engine
    Mar 2002
    will a cosworth hybrid turbo fit onto a vauxhall turbo engine and what advantages would the hybrid turbo have over the standard turbo.
    Oct 2001
    Kent
    the car in front
    Re: cosworth hybrid turbo onto cav turbo engine
    You can fit *any* turbo to *any* engine, provided you fabricate (or adapt) the necessary parts.
    However it's highly unlikely that they will match, as there are numerous little tiny parameters involved. So it will work, but will be nowhere near as good as the specially-designed item.
    Don't let them fool you that the 'hybrids' are the beez neez, spool faster, boost earlier, give far better top end, last longer and produce cooler charge, all at the same time. They don't.
    It's all give and take, mostly you give, bits you take - and if you don't like the way the car drives afterwards, tough!
    Hope it helps,
    John
    Mar 2002
    Thread Starter
    cheers.
  5. Remove Advertisements
    MWF
    MWF is offline
    Dec 2001
    Wolverhampton
    XR4i 3.1 Stage-2
    There is no such thing as a hybrid turbo, it just means something inside has been changed and it could be anything.
    The standard KKK turbo is a load of tosh and should be binned, Courtney do a manifold to mount a T3 (cossie).
  7. #5
    Jun 2000
    Leicester
    Astra SRi 1.9 CDTI XP 3DR
    I'm sorry - I though KKK were much better than Garret - hence they are fitted to Audi, Porsche and loads of other top end cars.
  8. #6
    carlisle, cumbria
    350bhp blown up nova
    mine is a hybrid kkk, richie has just bought a hybrid kkk, so there is such a thing
    dont believe the hype
    wanted - 2 false limbs and a wheelchair
  9. #7
    Dec 2000
    erm, actually they are a better quality turbo than garrett.
    Slightly different application but you don't wanna mention garrett turbos to a good friend of mine as they are always replacing them on the fleet of volvo trucks at the moment as the impeller shaft keeps snapping.
    "The more you turn the wick up the faster it goes" - John Welch
  10. #8
    MWF
    MWF is offline
    Dec 2001
    Wolverhampton
    XR4i 3.1 Stage-2
    OK then there is no such definition as a hybrid, it could mean anything has been done to a turbo.
    And the KKK fitted to the LET is not better than a Garret.
  11. #9
    Aug 2001
    Swindon, Wiltshire
    Astra J VXR/Ampera
    'tis
  12. #10
    carlisle, cumbria
    kkk's are a much better quality turbo rnt they????
    im sure they are.
    and there is such a thing as a hybrid turbo. and yes it means something inside has been chaged, and yes it could be anything but generally the hybrid ones spin up at lower rpm so whatever they change they change it for a reason, ie to make it better
  13. #11
    MWF
    MWF is offline
    Dec 2001
    Wolverhampton
    XR4i 3.1 Stage-2
    Or to sell them for more money cos it has hybrid on the side?
    KKK turbos are the Saxo VTS's of the turbo world, bleh, spits on floor, wipes bum with vauxhall badge.
  14. #12
    carlisle, cumbria
    great, yeah.
    fords are the same as saxos, common and rusty pieces off (edited) dung
  15. #13
    carlisle, cumbria
    but seriously, why is a garret any better?????? ive know loads of people with rs turbos to kill there garrets and have em set on fire and stuff coz therye crap. or so i thought.
    so explain whay they are better?????
  16. #14
    MWF
    MWF is offline
    Dec 2001
    Wolverhampton
    XR4i 3.1 Stage-2
    I wont play nice if you call my Ford dung, it's not it's fault it was born dissadvantaged.
    *strokes Garret*
  17. #15
    MWF
    MWF is offline
    Dec 2001
    Wolverhampton
    XR4i 3.1 Stage-2
    Garett are more reliable, have better bearings (kkk's have skinny shafts, poor quality bearings and are in efficient) more availability of different wheel/housing combos etc, its like comparing a e55 amg to a mondeo st200 estate, the merc is better in every way, both quality and reliability.
    Yes people do blow up Garrets, but then again people blow up Cav transfer boxes, does this make them worse than Ford ones? And yes they stick KKK's on Porchers but then again they stick Eaton superchargers on Astons and they have a habbit of bits breaking off and getting sucked into the engine.
    And for the last time calling a turbo a hybrid means little more than something has been messed with, could be a 360 degree thrust bearing, could be a different sixe impella or compressor, could be anything.
  18. #16
    near Glasgow....
    BMW 540i....
    KKK are crap turbos ??
    Audi, Cosworth and Porsche (to name but a few) dont seem to think so.
    The KKK K-16 turbo is a pretty good unit for the C20LET. At stock boost levels it does its job well with the integrated manifold/turbo unit cutting lag hugely.
    Sure, when you go above 1 bar of boost its not great but then thats not what its designed for.
    The Cav-Turbo Resource:
    Click Me
  19. #17
    Feb 2002
    London
    1992 Calibra Turbo
    HKS / Greddy turbos kicks both of them ok!!
    ______________________________
    I like Chips, but you cant beat a Superchip!!
  20. #18
    MWF
    MWF is offline
    Dec 2001
    Wolverhampton
    XR4i 3.1 Stage-2
    LOL Turbonetics make the best turbos.
  21. #19
    Feb 2002
    London
    1992 Calibra Turbo
    thats tuned for all that american qtr mile junk!
    pah i owned a 3 dr sierra...i loved it!! but then i discoverd that that vauxhalls are much better than fords in every way!!! fords rusted away like old tin can datsuns!!
    This are the cars i owned and how i rate them
    Mk1 Astra 1.2, 5/10
    Sierra 2.0 3dr 4/10
    Fiesta 950 2/10
    mk2 Cavalier 1.8 sri 8/10
    mk2 Astra 1.8 gte 7/10
    N13 Sunny 7/10
    Mk4 Supra Twin Turbo 9/10
    FTO 2.0 V6 Mivec 10/10
    Calibra Turbo 9/10
  22. #20
    MWF
    MWF is offline
    Dec 2001
    Wolverhampton
    XR4i 3.1 Stage-2
    LOL and I guess HKS and Greddy arn't.
    I have had a Vauxhall and a Ford, infact my best mate has a Vauxhall and I can't see any different between the two.
  23. #21
    Jul 2000
    Hampshire
    HKS Turbos are Garret turbos and Greddy use Mitsubishi Turbos.
    And I`m pickingup 2 of the greddy turbos tommorow
    Richard
  24. #22
    Feb 2002
    London
    1992 Calibra Turbo
    but they give it the jap tweek up......i`d love to go car gadget shopping in japan!!
  25. #23
    Oct 2001
    Kent
    the car in front
    I think you want to say "there is no such thing as a UNIVERSAL hybrid turbo" - which is true.
    "hybrid" is a synonym of "bastard" , as in some bits have been swapped/modified to better match a particular application.
    It just means that it's not identical to the 'stock' item, which, too, is arguably a hybrid (it was custom-made after testing dozens of variations, after all)
    Mine can boost to well over 20psi if needed, and it provides enough airflow for over 300lbft up to almost 5K revs.
    That's a lot of air being shoveled around, and the unit has 85K miles under its belt. Doesn't smoke either.
    It was designed to shift almost half the airflow.
    Tosh? I think not!...
  26. #24
    carlisle, cumbria
    so there, lol
  27. #25
    Oct 2001
    Kent
    the car in front
    Originally posted by Barnes
    ....but generally the hybrid ones spin up at lower rpm so whatever they change they change it for a reason, ie to make it better
    ...not exactly.
    You're confusing marketing blurb with measurable facts.
    Hybrids are meant to better match a particular setup (at the expense of inferior matching to any other setup)
    No, they don't generally spin at lower rpm, quite the opposite (although the marketing bull will claim otherwise)
    People usually shell out for 'hybrids' because they want more airflow at high engine revs - something that would quickly kill the stock units due to overrevving. Reliability at sustained high boost pressures is also a 'hybrid' aim, although these are not always proven.
    Just fitting a larger compressor wheel and/or a different turbine qualifies as a "hybrid" although performance may be impaired all around (remember that the manufacturer probably tested most of these hybridisation combos, but decided against them)
    Playing with A/R ratios is also hybridisation, but any which way you look at it, it's give and take (Bit like cams - is a wilder cam "better"? not necessarily, depends on the rest of the engine)
    I know for a fact that some well-know "hybrids" aren't worth their weight in scrap metal (just sloppily reconed stock units sold at a massive premium) You think that the punters notice? Nope! They're swapping a tired, smoking or siezed turbo with one that works, so it MUST be better, eh?
    So there
