In me Astra Sport runabout (2.0l ecowreck) it seems to use a bit of water, IE need to top up every 100-150 miles, it doesn't appear to be leaking as in a physical leak though...![]()
The heaters aren't very effective either IE kinda luke warm when engine is fully upto temp and when you undo the header tank cap there is some serious pressure in there, even if you leave it 1-2 days before opening it up there is still a lot of pressure!
The temp gauge reads normal on the dash, never goes over 100 etc...
I'm thinking it could just be a big arrrrse airlock but never really worked on a ecotec before so not entirely sure how to bleed them like the XE![]()
Any bright ideas?
Oh and the headgasket was replaced on this by the previous owner over a year ago...
Cheers![]()
lmao
