coscast head info
Results 1 to 21 of 21
Thread: coscast head info
    Nov 2005
    west yorkshire
    coscast head info
    right if i change the head may as well go all out
    but they seem to come with 100k + on the coscast heads
    how long exactly do these last ???? do they never ever go porus or do they eventually just a lot longer lasting then gm etc any info mega appreiciated
    they can and will,theres just less chance...cause of the better casting,
    Nov 2005
    west yorkshire
    so really a 100k one is quite likley to go porus then?
    Sep 2001
    Sheffield
    Mk2 Astra Estate
    theres less chance of it going porous than a normal KS head, but you can get KS heads with 150k plus and not go, its luck of the draw really.
    Nov 2005
    west yorkshire
    why not just go gm then? can get 70k ones for 70 quid or coscat 100k for 300 huge difference....
    cause people think there amasing...hence why i sold mine for 200sheets,
    Sep 2001
    Sheffield
    Mk2 Astra Estate
    coscast adds 50hp dont you know
    Nov 2005
    west yorkshire
    ok so are basic gm ones way to go then?
    Quote Originally Posted by Jamie_F View Post
    thats why they sell better...
    Quote Originally Posted by basscrazy View Post
    al the same..just wack a head on and go...
    Nov 2005
    west yorkshire
    will just get one of those then sodd paying extra nearley 3 hundred quid
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    Doesn't really matter how many miles a head has on it. It's a lump of metal. Unless it's been ran out of oil, has det damage, or has been skimmed to buggery, it'll be ok. Just don't tighten a KS down using 90deg lol.
    Condition is far more important than mileage. You could have a low mileage that hasn't been serviced, headgasket has gone 12 times and is pitted, or you could have a 200k head that's serviced, cared for, never had a HG.
    notts/derby
    nova SR
    personnaly id get a GM 1 and do the oil gallery modification
    prevention is better than repair
    "everyone loves a clean nova"
    Quote Originally Posted by draper View Post
    lol just fit the gm head drive it till it gos then fix it...
    Middlesex
    sideways
    mmm, there are some differences and some reasons why the coscast gets more money than a GM.
    The porousity of a std GM head doesn't really matter tbh, it's an easy fix.
    The Coscast head is cast from a better grade of aluminium, and has different valve seats and guides.
    Go to swindon race engines and they won't do you a head that isn't coscast... and that includes you supplying the head, they won't work on a std GM head.
    For example, increase the valve size +1mm and the GM head needs new seats allround, the coscast doesn't. Incidently, swindon's top head increases valve size 2mm all round.
    Brian Sidebotham.
    Jun 2002
    Wrectum
    Is it the material used or just the casting?
    It's much more homogenous and free from porosity (as in proper porosity, gas inclusion) than the KS heads, due to the magic Coscasting.
    May 2001
    South Wales
    Nippy Cav Turbo
    like my gm head which had 156 tho on and never went
    Macclesfield
    www.Retrobike.c
    Also iirc the misconception is the head goes porus, it does not it cracks as garys old pic's of the cut up head showed.
    Back in the scene
    Middlesex
    sideways
    Quote Originally Posted by Rick Draper View Post
    porous simply means that the oil gallery is no longer fully sealed against the water gallery and thats it; it means no more. How the head gets porous doesn't really matter. The GM head goes porous because of a weak spot in the casting, and the coscast head doesn't.
    Mr. Keen, It is supposely a different grade of ali. The main point is that it is nicer to machine/port than the GM head.
    Brian Sidebotham.
    MIGClub Member wayne451's Avatar
    Jan 2005
    The Internet.
    Mods round the bend...
    So a Coscast doesn't need anything to go 1mm oversize?
    Warren Buffett.
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    heres some info for you mofos
    courtesy of scooblers
    http://orsas.com/CarStuff/cav/
    Feb 2002
    West Yorks
    Vectra 3.2 GSI
    good site there GBE86
