turbo engine not turning but clicks
659 views 4 replies 4 participants last post by  Cavlad
#1 ·
i can get hold of a cav turbo problem is the engine gives a clicking sound when key is turned but doesnt turn if i turn it manually and it turns does that mean the engine is not seized apart from a faulty starter motor what else would cause this if it was a faulty starter or loose lead to starter would it still start if push started.
#5 ·
If ain't seized then you should be able to turn it over by hand,(clockwise) but from what your saying it sounds like you've got either a rather flat battery or the starter is buggered. I expect you've already checked the battery,so I'd say its the starter motor (solenoid) trying to engage the starter drive and can't. Give it tap a nd then try it. If still nothing remonve it and conect it to a battery(and hold it down) if it clicks then its probably the solenoid.
Hope this is of some help.
