Advertise Here - Click for More Info
Go Back   MIG Performance Vauxhalls > MIG Technical > Engines and Transmission
Engines and Transmission Technical forums for the discussion of all engine, transmission, turbo, ECUs, fuel systems and the like.
Old 23-01-2007, 13:59   #1
TELVM
Drives: Calibras 8V & Turbo
Section cut C20XE-C20LET head pictures?
Hi. I wonder if there are any pictures of a sectioned C20XE/C20LET cylinder head. I'd be particularly interested in a section cut following this transverse plane, right between the valves:
Thanks in advance.
TELVM is offline   Reply With Quote
Old 23-01-2007, 14:01   #2
chip
Drives: Like its stolen
Interesting topic, will watch this one
chip is offline   Reply With Quote
Old 23-01-2007, 14:18   #3
Add_Gee
Add_Gee's Avatar
Drives: BMW 320d (E46)
Any good? i know its not mid cylinder...
Add_Gee is offline   Reply With Quote
Old 23-01-2007, 14:39   #4
Nobbie
Central Regional Coordinator / Moderator
Nobbie's Avatar
Drives: Mk3 Astra GSi XE
I think Gary donated a porus head to be cut up, search for posts from Gary.
Central Region Co-ordinator
Central Region Forums/Events
Nobbie is offline   Reply With Quote
Old 23-01-2007, 15:37   #5
TELVM
Thanks Ad_Gee.
Tech drawings I found on the internet. Add some light but not yet what I need:
Old 23-01-2007, 15:48   #6
chip
What is it you need?
Old 23-01-2007, 15:49   #7
Nobbie
Nobbie's Avatar
Check this
http://www.migweb.co.uk/forums/mecha...ary+Porous+Pic
Old 23-01-2007, 16:01   #8
TELVM
The thickness of metal in the marked areas until you hit water.
Old 23-01-2007, 16:10   #9
Gary
the head I had cut was to investigate the oilway/waterway cracking issue - so the cut wasn't anywhere near those areas.
Keep I.D out of Science: http://bcseweb.org.uk
Gary is offline   Reply With Quote
Old 23-01-2007, 16:26   #10
chip
Is that so you can open them up to drop the CR, or skim the hell out of it to raise the CR, or for some other reason?
(sorry to be nosey, but sounds interesting!)
Old 23-01-2007, 16:28   #11
lee303
Drives: nova 1.8 16v on tbs
got one at the garage cut across the chamber like that, will dig it out and take a pic when i get a chance
lee303 is offline   Reply With Quote
Old 23-01-2007, 18:43   #12
TELVM
I'd be grateful would you be so kind Lee303 .
Is that so you can open them up to drop the CR, or skim the hell out of it to raise the CR, or for some other reason? (sorry to be nosey, but sounds interesting!)
Don't worry for asking. I need to know the thickness in those areas to be sure I will not hit water when cutting this:
Old 25-01-2007, 19:30   #13
TELVM
Did you find that slice Lee?
Old 25-01-2007, 20:14   #14
rodgerq
Drives: like a saint-9points
whats the cut for?
rodgerq
rodgerq is offline   Reply With Quote
Old 25-01-2007, 20:15   #15
lee303
not yet, will be up there this weekend though so should be able to get some snaps then
Old 25-01-2007, 20:15   #16
sbd16vastra
Drives: wife around the bend
what is the idea behind those cuts never seen anything like that before
''THE REAL ROB''
sbd16vastra is online now   Reply With Quote
Old 25-01-2007, 20:22   #17
wayne451
Drives: Pie truck to OHC's
I remember reading something on an American site and its primary reasoning was for fuel consumption, although there were other benefits that I forget!?!?
wayne451 is offline   Reply With Quote
Old 25-01-2007, 20:28   #18
Nemesis
Drives: Calibra touring car
Are you sure he's not just testing the depth to see if there is a water jacket underneath? ie he can weld up a slit, but not a whole area that's been rubbed back!
Diet Nemesis
Nemesis is offline   Reply With Quote
Old 25-01-2007, 20:33   #19
0ddball
the slits are meant help channel the compressed fuel and air into the spark plug area. i.e "squish"
not such a big deal on pentroof (V) 16v chambers since the charge gets pushed to the plug anyway. i think the other thread with these modifications to kidney shaped 8v heads are much more effective and a bigged deal.
0ddball is offline   Reply With Quote
Old 25-01-2007, 20:42   #20
Nemesis
(edited)
... beat me to it
Blydenstein don't do this mod on the XE/LET engines do they? Neither do any of the major tuners?
Old 25-01-2007, 20:48   #21
Rs1
Drives: LET...coming soon
Is it gonna be left at just the slits thought? Or is he gonna machine it away to make the chamber completly round....upto the marking on the face? Therefore there will be no slits when its finished perhaps, just a larger combustion chamber??
Good **** though, crack on.
"THE ROB"
Rs1 is offline   Reply With Quote
Old 25-01-2007, 20:55   #22
rodgerq
surely they slits, left like that, provide a way for the mixture to escape from the combustion chamber and generally a leaky combustion chamber. or am i not thinking straight here:
rodgerq
Old 25-01-2007, 20:57   #23
wayne451
How? They would sit inside the fire ring of the gasket!
Old 25-01-2007, 21:02   #24
Nemesis
A slit like that would also have several sharp edges = det hotspots.
Old 25-01-2007, 21:02   #25
rodgerq
seeeee, i told you i could be thinking wonky
rodgerq
©MIGWeb 1997-2009 - MIGWeb Home - Archive - Privacy Statement - Top
Powered by: vBulletin. Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0
