Page 7 of 61 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 57 ... LastLast
Results 151 to 175 of 1504
Thread: Isuzu turbo diesel tuning guide
  1. #151
    Oct 2005
    Benn's garage
    hitler's taxi
    jack, if i ask you for help on a build, would you mind?
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Not at all mate.
  4. #153
    Oct 2005
    Benn's garage
    hitler's taxi
    yay will be in touch soon
  5. #154
    Jul 2006
    Ipswich
    corsa 1.8 8v
    hi
    i had a 1.5 td nova van i fitted a bleed valve
    pluged the reseculating valve
    put 1/4 turn on the fule pressure
    removed the intake box and replaced with a k&n
    stuck the exhaust out just under the drivers door with no boxes in it
    it was a beast
    it ran 1.2 bar
    at east coast xtream i ran a 17 sec 1/4 mile against a nove gte who just beat me at the 1/4 line.
  6. #155
    Oct 2005
    Benn's garage
    hitler's taxi
    was it very loud with no boxes? how much smoke did you get with no boxes??
  7. #156
    Jul 2006
    Ipswich
    corsa 1.8 8v
    only smoked until it came on boost then it cleared.
    with the reserc valve taken off it use to dump boost through the exhaust
    it was loud but bearable. i had to machine a plug for the end of the exhaust to reduce the diameater down from 2.5 in to 1in for early mornings to go to work
  8. #157
    Banned
    Nov 2007
    worcs
    like its leased
    Wink
    Quote Originally Posted by reno View Post
    plastic back box? are you for real
    sadly iam...... i will post a pic sometime-bloody light with s/s twin exit pipes
    the plastic holds the heat and thus keeps it lighter and goes out faster lollmao
    i used a bleed valve and it was tremedous fun until i melted the HG between the 2 middle bores
    iam interested in the propane idea is it just a jet into the induction hose?
    will this propane cuase even more heat and blow the HG?
  9. #158
    Oct 2005
    Benn's garage
    hitler's taxi
    Quote Originally Posted by novrod View Post
    sweet
    on another note, is there any way to prevent it from smoking after the boost has been turned up?
  10. #159
    Jul 2006
    Ipswich
    corsa 1.8 8v
    i had a message from a guy in germany saying
    turn the fuel pressure up
    then if it smokes on boost its too high
    so back it off till it stops then the mixture should be ok
  11. #160
    Oct 2005
    Benn's garage
    hitler's taxi
    no lol...you know after you have turned the fuel and boost up to the correct level you get black smoke before it comes on boost, is there a way to stop that black smoke?
  12. #161
    Jul 2006
    Ipswich
    corsa 1.8 8v
    on my limited knowledge i would say no as the smoke is caused by the mixture being so rich of fuel before the oxygen is forced in buy the turbo.
  13. #162
    Oct 2005
    Benn's garage
    hitler's taxi
    ahhhh right...i never knew exactly why it smoked after the boost/fuel was turned up ive learnt a few things today
  14. #163
    Dec 2005
    UK
    Quote Originally Posted by Grim Reaper View Post
    If the air/fuel ratio is correct, you won't get any smoke.
  15. #164
    Oct 2005
    Benn's garage
    hitler's taxi
    ahhh is that where the hot and cold idle screws or something come into play??
  16. #165
    Oct 2005
    Benn's garage
    hitler's taxi
    also, whats involved in adding a turbo to a non turbo diesel??? is it the same concept as a petrol? obviosly a manifold will have to be made and the correct pizza has to be used but what else??
  17. #166
    Dec 2005
    UK
    More or less the same as a petrol car, except you can be a bit more vague with the fuelling.
    The fuel pump will obviously need to know somehow how much boost you're on. On Isuzu engines, this is a small hose that goes from the back of the inlet to the top of the fuel pump.
    If you're not after crazy performance, and just a modest increase, slap a turbo on, up the fuelling across the board and be prepared for some serious smoke.
    You might need to lower the CR for a lot of boost.
  18. #167
    Aug 2002
    surrey
    GOT E30 YER
    Quote Originally Posted by Jack View Post
    Get your fuelling sorted first.
    That was welded up ages ago before it was even on the road. Not sure how to do the fueling other than paying a diesel tuning place lots of money to put it right
  19. #168
    Aug 2002
    surrey
    GOT E30 YER
    I've tried mine with just the downpipe and no exhaust system before and boy was it loud like a tractor on speed lol went up to 26psi
  20. #169
    Oct 2005
    Benn's garage
    hitler's taxi
    i wouldnt mind having very nice performance how would i go about doing it properly then?? custom management??
    also just read my post above, pizza??? thats what happens if you try and have 2 convirsations at the same time lmao
  21. #170
    Dec 2005
    UK
    Yeah, see if you can get the head of a new Civic diesel to fit and use the common rail stuff.
  22. #171
    Oct 2005
    Benn's garage
    hitler's taxi
    http://www.youtube.com/watch?v=FR0faI8nzSM
    watch that video, then see the second car...thats the noise im after
  23. #172
    Dec 2005
    UK
  24. #173
    Oct 2005
    Benn's garage
    hitler's taxi
    thats the engine im gonna be working with
  25. #174
    Dec 2005
    UK
    I love you.
  26. #175
    Oct 2005
    Benn's garage
    hitler's taxi
    do you drink?? *serious question*
  1. 10-02-2012, 08:51
  2. 05-02-2012, 17:34
  3. 26-01-2012, 11:58
  4. 17-01-2012, 09:43
  5. 13-01-2012, 01:44
  6. 30-12-2011, 02:52
  7. 10-12-2011, 22:43
  8. 10-12-2011, 22:02
  9. 06-11-2011, 20:24
  10. 21-10-2011, 14:56
  11. 19-10-2011, 19:29
  12. 18-09-2011, 14:04
  13. 12-09-2011, 09:08
  14. 11-09-2011, 12:25
  15. 01-09-2011, 21:23
  16. 29-08-2011, 17:55
  17. 25-07-2011, 00:02
  18. 17-07-2011, 22:16
  19. 15-07-2011, 01:24
  20. 06-06-2011, 18:05
  21. 01-06-2011, 20:03
  22. 28-05-2011, 16:33
  23. 28-05-2011, 16:33
  24. 19-05-2011, 23:38
  25. 19-05-2011, 16:50
  26. 13-05-2011, 23:35
  27. 03-05-2011, 12:38
  28. 29-04-2011, 21:00
  29. 22-04-2011, 05:09
  30. 16-04-2011, 08:23
  31. 12-04-2011, 19:35
  32. 11-04-2011, 19:37
  33. 09-04-2011, 09:47
  34. 29-03-2011, 21:15
  35. 16-03-2011, 18:46
  36. 27-02-2011, 09:49
  37. 18-02-2011, 18:20
  38. 10-02-2011, 23:39
  39. 06-02-2011, 11:06
  40. 05-02-2011, 20:42
  41. Isuzu
    Refback This thread
    03-02-2011, 20:47
  42. 18-01-2011, 12:12
  43. 12-01-2011, 22:45
  44. 12-01-2011, 20:03
  45. 12-01-2011, 19:38
  46. 04-01-2011, 12:50
  47. 27-12-2010, 11:57
  48. 23-12-2010, 13:33
  49. 18-12-2010, 16:11
  50. 24-11-2010, 11:42
  51. 18-11-2010, 22:41
  52. 18-11-2010, 21:49
  53. 05-11-2010, 04:57
  54. boost
    Refback This thread
    05-11-2010, 00:10
  55. 04-11-2010, 01:20
  56. 03-10-2010, 18:12
  57. 03-10-2010, 17:41
  58. 26-09-2010, 04:28
  59. 14-09-2010, 20:12
  60. 07-09-2010, 22:16
  61. 31-08-2010, 18:04
  62. 30-08-2010, 20:12
  63. 24-08-2010, 21:55
  64. 15-07-2010, 01:54
  65. 14-07-2010, 23:04
  66. 12-07-2010, 19:52
  67. 06-07-2010, 12:50
  68. 28-06-2010, 02:29
  69. 22-06-2010, 13:44
  70. 12-06-2010, 12:36
  71. 05-06-2010, 11:35
  72. 04-06-2010, 22:43
  73. 25-05-2010, 17:06
  74. 18-05-2010, 18:58
  75. 16-05-2010, 19:26
  76. 15-05-2010, 09:31
  77. 13-05-2010, 17:02
  78. 13-05-2010, 16:51
  79. 12-05-2010, 13:04
  80. 06-05-2010, 17:02
  81. 29-04-2010, 19:56
  82. 26-04-2010, 12:24
  83. 25-04-2010, 19:35
  84. 18-04-2010, 20:13
  85. 13-04-2010, 20:03
  86. 13-04-2010, 06:16
  87. 10-04-2010, 18:48
  88. 22-03-2010, 13:48
  89. 21-03-2010, 10:02
  90. 21-03-2010, 04:21
  91. 18-03-2010, 18:57
  92. 17-03-2010, 19:27
  93. 17-03-2010, 19:08
  94. 13-03-2010, 14:20
  95. 08-03-2010, 13:05
  96. 04-02-2010, 09:15
  97. 28-01-2010, 12:35
  98. 26-01-2010, 01:08
  99. Clix
    Refback This thread
    23-01-2010, 00:02
  100. 01-01-2010, 21:01
  101. 03-12-2009, 08:02
  102. 25-11-2009, 23:10
  103. *Clix
    Refback This thread
    18-11-2009, 11:46
  104. 13-11-2009, 21:36
  105. 08-11-2009, 11:01
  106. 26-07-2009, 16:55
  107. 26-07-2009, 12:42
  108. 23-07-2009, 12:05
  109. 22-07-2009, 22:59
  110. 21-07-2009, 20:27
  111. 21-07-2009, 14:34
  112. 05-07-2009, 20:15
  113. 04-07-2009, 22:11
  114. 30-06-2009, 12:55
  115. 21-06-2009, 22:12
  116. 25-05-2009, 15:32
  117. 17-05-2009, 17:12
  118. 17-05-2009, 11:26
  119. 16-05-2009, 19:53
  120. 01-05-2009, 18:00
  121. 01-05-2009, 17:50
  122. 10-04-2009, 20:39
  123. 04-04-2009, 06:05
  124. 31-03-2009, 14:56
  125. 11-02-2009, 17:44
  126. 10-02-2009, 23:31
  127. 02-02-2009, 10:31
  128. 26-12-2008, 11:59
  129. 20-12-2008, 18:58
  130. 15-12-2008, 21:45
  131. 07-12-2008, 14:47
  132. 07-12-2008, 11:16
  133. 07-12-2008, 00:23
  134. 06-12-2008, 23:18
  135. 06-12-2008, 23:17
  136. 03-12-2008, 20:29
  137. 16-11-2008, 22:45
  138. 15-11-2008, 21:21
  139. 15-11-2008, 11:28
  140. 15-11-2008, 09:07
  141. 16-07-2008, 19:07
  142. 19-06-2008, 15:32
  143. 10-06-2008, 20:06
  144. 10-06-2008, 17:01
  145. 30-05-2008, 20:44
