Page 5 of 61 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 55 ... LastLast
Results 101 to 125 of 1504
Thread: Isuzu turbo diesel tuning guide
  1. #101
    Oct 2002
    North London
    Astra TD/Astra Sport
    well i guess i was hoping to just swap it over to a factory one if possible, trust me these are expensive from vauxhall im pretty sure they were over £65 wouldnt have minded paying £20-£30 but thats to much for a bit of rubber piping
    if anyone could get some for me when they are at the breakers i would appreciate that i dont really have to much spare time in the day, hence why all my repairs are done in the dark which isnt fun
    Owns a white Mk3 turbo diesel with more stopping power then engine power..... boosting 0.9bar, Now De-catted!!
    Aug 2002
    surrey
    GOT E30 YER
    Cant you go to the motor factors and buy some similar shaped pipes fromt he odds n sods box?
    Or try some other cars at the scrappys?
  4. #103
    Oct 2002
    North London
    no scrappies i know off that arent miles away from me or would charge the same as vauxhall, as said pipes have a few connections and joied at some point so cant use single hosing
    was thinking should cut the hole out and use something to reconnect the pipes although im not quite sure what
  5. #104
    Jan 2007
    Scotland
    hey guys, is there a better inlet manifold to go for? or a bigger turbo, i.e frontera 2.8? thought u mite get some stuff off them?
  6. #105
    Aug 2002
    surrey
    GOT E30 YER
    Mod your manifold for a t3
  7. #106
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Get a tubular one made up.
    I don't know how much the rods would take, by the way. I know Rich C bent some when he was on gas.
  8. #107
    Aug 2002
    surrey
    GOT E30 YER
    120hp of gas i think lol, you got my cheque yet?
  9. #108
    Dec 2005
    UK
    Yes I have matey.
    Anyone know if post offices are open today? I can post it now. I've included all the bolts too.
    Yours is nicer than mine. On mine the "TURBO" is a red sticker, yours is actually part of the plastic.
  10. #109
    Dec 2005
    UK
    Yeah, he has a nuts engine.
    I'm going to rebuild an Isuzu TD when I have some money.
  11. #110
    Aug 2002
    surrey
    GOT E30 YER
    thats fine mate, PS arent open sundays just wondered if you got it thats all, post it when you have time. Dont worry about bolts there still attatched to the smashed one. Swap'em over if you want the turbo on yours, i dont care lol
  12. #111
    Dec 2005
    UK
    I've already wrapped it up lovingly in a towel and stuff, it's all ready to go as soon as I can get to the post office.
    Bolts are in there too, so you're having them.
  13. #112
    Jan 2007
    Scotland
    t3? where would i get one? and how long before my engine goes bang! lol
    1. What kind of bleed valve do i need and where do i get it?
    2. how do i fit it lol
    3. can you up the boost? how to? take it fitting any boost gauge works?
    4. Can you get a dump valve? and does it sound good or lyk a jcb fastrac? lol
  14. #113
    Dec 2005
    UK
    Quote Originally Posted by tiny sri View Post
    1) eBay, do some research.
    2) Again, use the search button, you have to modify some pipework near the turbo.
    3) You use the bleed valve to control your amount of boost. Worth getting a boost gauge too.
    4) Of course you can get dump valves, but then it will just sound like a diesel with a dump valve.
  15. #114
    Aug 2005
    sheffield
    integra type r
    ive fitted an mbc, done the white ring and upped the fuelling by 1/3 of a turn on my astra it now runs 1.1 bar and drives much better throughout the revrange above 2500rpm!
    sputum-filled piece of
    distended rectum incompetents of the highest order.
  16. #115
    Dec 2005
    UK
    Quote Originally Posted by bonelorry View Post
    Could you get away with turning it any more? The general rule is turn it until it smokes on boost, then sneak it back a bit.
  17. #116
    Oct 2004
    gloucestershire
    99 astra 1.8s
    does anybody do this at a garage as i can not be arsed or would anyone want to do it to my silver cav 1.7td cdx
    98.9p/L why is diesel more epensive now
  18. #117
    Oct 2002
    North London
    Quote Originally Posted by zak_godsell View Post
    would take you around 2-3 hours max to do this yourself its a piece of piss
  19. #118
    Dec 2005
    Telford
    astra TD Tuned
    any one know if i could use a frontera front mount intercool and be able to plumb it in like a LET, got a mk3 astra TD isuzu lump any pro's and cons too doing this?
  20. #119
    Aug 2002
    surrey
    GOT E30 YER
    yes you can use the i.c. if you can find one, i'm running without a nut in the bleed valve so its just open not by choice it dropped out cba to put one in. Works fine and puts out 22-23psi on standard i.c.
    cone filter straight off the turbo helps with cooling and makes a cool whistle.
  21. #120
    Dec 2005
    Telford
    astra TD Tuned
    what about **** being let thru the cone filter? it will kill the turbo blades wnt it. am i right in thinking the standard IC is on top of the engine? as i wanted it in the front bumper, will cut out a space for it in my GLS bumper (basicly the same as a sport bumper)
  22. #121
    Oct 2002
    North London
    your thinking about pugs, the intercooler is on the rad (passenger side) probably a good idea to put it somewhere that would be more open e.g. (in front of) the bottom of the rad
    22psi thats pretty high, must be pretty quick although laggie
  23. #122
    Dec 2005
    Telford
    astra TD Tuned
    yeah, so i can replace it then with a frontera front mount job, or what about them custom ones that are universal? just a slimline one like this
    would i gain some bhp by adding one, also, can you run a bigger turbo on these derv engines?
  24. #123
    MIGClub Member tommychimp's Avatar
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    Jack i'm seriously tempted to get Mk3 astra sport diesel, all this boost for so little effort sounds like an awesome idea.
    3.0 V6 CDTI Vectra SRI
    You can't get thicker than a Kwik-fit fitter.
  25. #124
    Dec 2005
    Telford
    astra TD Tuned
    sounds fcuking ace dont it pal
  26. #125
    Dec 2005
    Telford
    astra TD Tuned
    this would work woundnt it?? http://cgi.ebay.co.uk/FRONT-MOUNT-TU...QQcmdZViewItem
    anyone shead any light?
  1. 10-02-2012, 08:51
  2. 05-02-2012, 17:34
  3. 26-01-2012, 11:58
  4. 17-01-2012, 09:43
  5. 13-01-2012, 01:44
  6. 30-12-2011, 02:52
  7. 10-12-2011, 22:43
  8. 10-12-2011, 22:02
  9. 06-11-2011, 20:24
  10. 21-10-2011, 14:56
  11. 19-10-2011, 19:29
  12. 18-09-2011, 14:04
  13. 12-09-2011, 09:08
  14. 11-09-2011, 12:25
  15. 01-09-2011, 21:23
  16. 29-08-2011, 17:55
  17. 25-07-2011, 00:02
  18. 17-07-2011, 22:16
  19. 15-07-2011, 01:24
  20. 06-06-2011, 18:05
  21. 01-06-2011, 20:03
  22. 28-05-2011, 16:33
  23. 28-05-2011, 16:33
  24. 19-05-2011, 23:38
  25. 19-05-2011, 16:50
  26. 13-05-2011, 23:35
  27. 03-05-2011, 12:38
  28. 29-04-2011, 21:00
  29. 22-04-2011, 05:09
  30. 16-04-2011, 08:23
  31. 12-04-2011, 19:35
  32. 11-04-2011, 19:37
  33. 09-04-2011, 09:47
  34. 29-03-2011, 21:15
  35. 16-03-2011, 18:46
  36. 27-02-2011, 09:49
  37. 18-02-2011, 18:20
  38. 10-02-2011, 23:39
  39. 06-02-2011, 11:06
  40. 05-02-2011, 20:42
  41. Isuzu
    Refback This thread
    03-02-2011, 20:47
  42. 18-01-2011, 12:12
  43. 12-01-2011, 22:45
  44. 12-01-2011, 20:03
  45. 12-01-2011, 19:38
  46. 04-01-2011, 12:50
  47. 27-12-2010, 11:57
  48. 23-12-2010, 13:33
  49. 18-12-2010, 16:11
  50. 24-11-2010, 11:42
  51. 18-11-2010, 22:41
  52. 18-11-2010, 21:49
  53. 05-11-2010, 04:57
  54. boost
    Refback This thread
    05-11-2010, 00:10
  55. 04-11-2010, 01:20
  56. 03-10-2010, 18:12
  57. 03-10-2010, 17:41
  58. 26-09-2010, 04:28
  59. 14-09-2010, 20:12
  60. 07-09-2010, 22:16
  61. 31-08-2010, 18:04
  62. 30-08-2010, 20:12
  63. 24-08-2010, 21:55
  64. 15-07-2010, 01:54
  65. 14-07-2010, 23:04
  66. 12-07-2010, 19:52
  67. 06-07-2010, 12:50
  68. 28-06-2010, 02:29
  69. 22-06-2010, 13:44
  70. 12-06-2010, 12:36
  71. 05-06-2010, 11:35
  72. 04-06-2010, 22:43
  73. 25-05-2010, 17:06
  74. 18-05-2010, 18:58
  75. 16-05-2010, 19:26
  76. 15-05-2010, 09:31
  77. 13-05-2010, 17:02
  78. 13-05-2010, 16:51
  79. 12-05-2010, 13:04
  80. 06-05-2010, 17:02
  81. 29-04-2010, 19:56
  82. 26-04-2010, 12:24
  83. 25-04-2010, 19:35
  84. 18-04-2010, 20:13
  85. 13-04-2010, 20:03
  86. 13-04-2010, 06:16
  87. 10-04-2010, 18:48
  88. 22-03-2010, 13:48
  89. 21-03-2010, 10:02
  90. 21-03-2010, 04:21
  91. 18-03-2010, 18:57
  92. 17-03-2010, 19:27
  93. 17-03-2010, 19:08
  94. 13-03-2010, 14:20
  95. 08-03-2010, 13:05
  96. 04-02-2010, 09:15
  97. 28-01-2010, 12:35
  98. 26-01-2010, 01:08
  99. Clix
    Refback This thread
    23-01-2010, 00:02
  100. 01-01-2010, 21:01
  101. 03-12-2009, 08:02
  102. 25-11-2009, 23:10
  103. *Clix
    Refback This thread
    18-11-2009, 11:46
  104. 13-11-2009, 21:36
  105. 08-11-2009, 11:01
  106. 26-07-2009, 16:55
  107. 26-07-2009, 12:42
  108. 23-07-2009, 12:05
  109. 22-07-2009, 22:59
  110. 21-07-2009, 20:27
  111. 21-07-2009, 14:34
  112. 05-07-2009, 20:15
  113. 04-07-2009, 22:11
  114. 30-06-2009, 12:55
  115. 21-06-2009, 22:12
  116. 25-05-2009, 15:32
  117. 17-05-2009, 17:12
  118. 17-05-2009, 11:26
  119. 16-05-2009, 19:53
  120. 01-05-2009, 18:00
  121. 01-05-2009, 17:50
  122. 10-04-2009, 20:39
  123. 04-04-2009, 06:05
  124. 31-03-2009, 14:56
  125. 11-02-2009, 17:44
  126. 10-02-2009, 23:31
  127. 02-02-2009, 10:31
  128. 26-12-2008, 11:59
  129. 20-12-2008, 18:58
  130. 15-12-2008, 21:45
  131. 07-12-2008, 14:47
  132. 07-12-2008, 11:16
  133. 07-12-2008, 00:23
  134. 06-12-2008, 23:18
  135. 06-12-2008, 23:17
  136. 03-12-2008, 20:29
  137. 16-11-2008, 22:45
  138. 15-11-2008, 21:21
  139. 15-11-2008, 11:28
  140. 15-11-2008, 09:07
  141. 16-07-2008, 19:07
  142. 19-06-2008, 15:32
  143. 10-06-2008, 20:06
  144. 10-06-2008, 17:01
  145. 30-05-2008, 20:44
