Page 45 of 61 FirstFirst ... 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 ... LastLast
Results 1,101 to 1,125 of 1504
Thread: Isuzu turbo diesel tuning guide
  1. #1101
    Sep 2004
    Hants/Beds
    Re: Isuzu turbo diesel tuning guide
    Very interesting reading....watch this space....
    Dec 2005
    Telford
    astra TD Tuned
    im having my head removed to have the inlet valves changed and refaced. or something like that, at a engine shop, is there anything i should know about setting the timing back up on these? as i think ill probly ask my uncle to do it as he's a mechanic himself, also ill need a new headgasket kit too, anyone know where i can get a good timing belt kit from?
  4. #1103
    Jul 2009
    west mids
    1.7td corsa van
    hi guys,
    ive recently changed the turbo on my 1.5td corsa to a RHB4 of the 1.7 cav.
    ive also increased the fuel and removed the white ring, i also fitted a frontera intercooler and an old N/A inlet manifold.
    ive got an air filter straight onto the turbo then through the intercooler to the inlet manifold.
    however my problem is ive fitted a bleed valve and im still only getting 0.5bar of boost and wen i come onto boost theres thick white/grey smoke cumming out the back.
    basically is it the turbo's nackerd or is sumithing else wrong?
    thanks
  5. #1104
    Jan 2008
    Wiltshire, UK
    isuzu TD estate CDX
    sounds like turbo is shagged mate
  6. #1105
    Jan 2009
    The Netherlands
    '95 Corsa 1.7 TDS
    Think the turbo indeed
    '95 Corsa 1.5 D @ 1.7 TDS with an IHI RHF4
  7. #1106
    Dec 2005
    Telford
    astra TD Tuned
    anyone know what size outlets are on the frontera intercooler and what pipe work im going to need to plumb it all into a astra? im thinking 2 90o bends, some straights and 45o?
  8. #1107
    Dec 2005
    Telford
    astra TD Tuned
    also any links to propane use in TD's?
  9. #1108
    Jul 2009
    newcastle
    xe powerd locost
    hi just wondering has anyone out there tinkerd with the newer 1.7dti found in my 02 corsa van, ive just sold my megane 225 due to buying a house with my lass, and cant afford to tax and test my kit car so i looking to have sum cheap fun if possible is it possible to turn up the boost etc?
  10. #1109
    Jul 2009
    west mids
    1.7td corsa van
    Quote Originally Posted by reno View Post
    you need 51mm internal diameter for the outlets
  11. #1110
    Jun 2004
    Twisk, Holland
    '97ComboD '93NovaTD
    http://www.mrsharkey.com/lpg.htm
    IWEMA enterprise, diesel on LPG
    Commercial systems:
    P.I.Fuel Systems Ltd - Powershot Diesel
    Allisport Powershot Propane Injection Kit bei eBay.de: Performance Tuning Parts (endet 02.03.10 00:03:17 MEZ)
    (Allisport sells the american Powershot 2000 system, different from the one P.I. fuelsystems sell)
  12. #1111
    Oct 2009
    Hungary
    Corsa B 1.5TD '97
    Today I fitted a new (RHF4) turbo and something not good. The car smokes a lot more at the same pressure (max 1bar) and not stronger then before.....And at the same speed the pressure is mutch bigger...ect. 80mhp RHF3 0.3-0.4bar, now RHF4 0.6bar.
    Someone help please!
  13. #1112
    Apr 2008
    strath,Fife
    cavi,XJ6 manual !!
    anybody interested in going veriable vane as i have 2 vb14 ihi turbos which are rhf4v and i cant see it being to hard to control the boost if u used a external wastegate these turbos are no more than 2 years old and work fine thay have been kept in a bag to i will upload some pics if u want
    dream project lotus carlton lump in a viva on ms and 2.1 bar!
  14. #1113
    Apr 2008
    strath,Fife
    cavi,XJ6 manual !!
    pics
  15. #1114
    Apr 2008
    strath,Fife
    cavi,XJ6 manual !!
    i also have a big lpg tank and its 3/4 full lol if someone wants to build a savage savage td
  16. #1115
    Oct 2009
    Hungary
    Corsa B 1.5TD '97
    Longer transmission:
    I found this (www.opel-infos.de):
    Schaltgetriebe:
    F13WR, 3,74
    Eco: F13WR, 3,35 (0797* -)
  17. #1116
    Jun 2004
    Twisk, Holland
    '97ComboD '93NovaTD
    @eggman:
    When you undo the clamp, can you rotate the cartridge+compressor freely (i.e. reclock the turbo).
    (would be pretty cool, as with the garretts you have to take it apart to reclock it)
    The A/R of 13 vs our RHB4's 11 and RHF4's 10 is also a nice step up. (less restriction, and with the vanes still very responsive)
    Matt's IHI Turbo Page <p>IHI = Ishikawajima-Harima Heavy Industries.
    @KertAce:
    The 3.35 is nice, but i've only heard of them...never actually seen one !
  18. #1117
    Jan 2009
    The Netherlands
    '95 Corsa 1.7 TDS
    Quote Originally Posted by DutchNovaDiesel View Post
    @eggman:
    Nice page.
    I tried to rotate the compressor of my RHF5 with the clamp off. Put it in a vice, tried to rotate it with all the power i have, but it didnt give an inch! Any tips on dealing with this without breaking it?
  19. #1118
    Jan 2010
    near Ashford, Kent
    '93 corsa 1.5td
    to all those who have fitted the n/a inlet,please can you tell me where you took the vacuum feed for the diesel pump from? and how did you block up the breather pipe found on the front of the inlet? thanks in advance, seb
  20. #1119
    Jul 2009
    west mids
    1.7td corsa van
    Quote Originally Posted by sebbyg View Post
    i pulled the pipe and the metal thing out my TD inlet then drilled a hole in the same place on the N/A inlet and put it and put sum liquid metal around it to make it air tight.
    and for the breather pipe i just put a bolt in the pipe and clamped it on
  21. #1120
    Apr 2008
    strath,Fife
    cavi,XJ6 manual !!
    @dutchnovadiesel dont know give me your address and i will post u one for peanuts if u want i also have 2 far bigger T4 sized vv garret blowers
    if u want a play with them??
  22. #1121
    Jul 2009
    west mids
    1.7td corsa van
    anyone interested in a frontera intercooler?
    im selling mine on, only want wat i paid for it Ł35
  23. #1122
    Dec 2005
    Telford
    astra TD Tuned
    Headgaskets are steel layered items, original and aftermarket should be the same (the ones i've seen were all good).
    Here's an even cheaper one: http://cgi.ebay.co.uk/ISUZU-GEMINI-1...3A1|240%3A1318
    What manifold is on your engine, does it have the plastic filter housing on top or is it all aluminium ?
    Here's one from an early corsa, with some modifications: lmao
    And what it looked like:
    This is the one on later models: (this is from an n/a model, which has a single inlet on the driverside)
    To fit this, you need to block the breather connection (see pic), and add the connection for the fuel pump (drill a 4mm hole, and swap or add a connection...just like in the first pic.)
    i want to run this inlet as it will be easier to add boost pipes and bigger intercooler.
    any more details on what i need to mod to use this inlet on a 1.7TD astra
  24. #1123
    Jan 2009
    The Netherlands
    '95 Corsa 1.7 TDS
    Use the bottom half of your 1.7TD, so all the vacuumfeeds stay where they are. You have to seal the inlet of the charged air, use a blank plate with a gasket and bolt it on. Then use the upper half of the n/a inlet. This way its easier cuz you dont have to make extra holes and stuff.
  25. #1124
    Jul 2009
    west mids
    1.7td corsa van
    i just used that inlet straigh onto my 1.5 blocked the breather hose with a bolt and drilled a small hole in the back for the vacum feed.
    im only down the road in newport so if you want to come and have a gander few free
  26. #1125
    Eastern Regional Coordinator Spinbitch's Avatar
    Sep 2003
    Colchester, Essex
    MK3 Astra & Dis
    Well i've picked up a new motor today, back in the Isuzu gang.
  1. 10-02-2012, 08:51
  2. 05-02-2012, 17:34
  3. 26-01-2012, 11:58
  4. 17-01-2012, 09:43
  5. 13-01-2012, 01:44
  6. 30-12-2011, 02:52
  7. 10-12-2011, 22:43
  8. 10-12-2011, 22:02
  9. 06-11-2011, 20:24
  10. 21-10-2011, 14:56
  11. 19-10-2011, 19:29
  12. 18-09-2011, 14:04
  13. 12-09-2011, 09:08
  14. 11-09-2011, 12:25
  15. 01-09-2011, 21:23
  16. 29-08-2011, 17:55
  17. 25-07-2011, 00:02
  18. 17-07-2011, 22:16
  19. 15-07-2011, 01:24
  20. 06-06-2011, 18:05
  21. 01-06-2011, 20:03
  22. 28-05-2011, 16:33
  23. 28-05-2011, 16:33
  24. 19-05-2011, 23:38
  25. 19-05-2011, 16:50
  26. 13-05-2011, 23:35
  27. 03-05-2011, 12:38
  28. 29-04-2011, 21:00
  29. 22-04-2011, 05:09
  30. 16-04-2011, 08:23
  31. 12-04-2011, 19:35
  32. 11-04-2011, 19:37
  33. 09-04-2011, 09:47
  34. 29-03-2011, 21:15
  35. 16-03-2011, 18:46
  36. 27-02-2011, 09:49
  37. 18-02-2011, 18:20
  38. 10-02-2011, 23:39
  39. 06-02-2011, 11:06
  40. 05-02-2011, 20:42
  41. Isuzu
    Refback This thread
    03-02-2011, 20:47
  42. 18-01-2011, 12:12
  43. 12-01-2011, 22:45
  44. 12-01-2011, 20:03
  45. 12-01-2011, 19:38
  46. 04-01-2011, 12:50
  47. 27-12-2010, 11:57
  48. 23-12-2010, 13:33
  49. 18-12-2010, 16:11
  50. 24-11-2010, 11:42
  51. 18-11-2010, 22:41
  52. 18-11-2010, 21:49
  53. 05-11-2010, 04:57
  54. boost
    Refback This thread
    05-11-2010, 00:10
  55. 04-11-2010, 01:20
  56. 03-10-2010, 18:12
  57. 03-10-2010, 17:41
  58. 26-09-2010, 04:28
  59. 14-09-2010, 20:12
  60. 07-09-2010, 22:16
  61. 31-08-2010, 18:04
  62. 30-08-2010, 20:12
  63. 24-08-2010, 21:55
  64. 15-07-2010, 01:54
  65. 14-07-2010, 23:04
  66. 12-07-2010, 19:52
  67. 06-07-2010, 12:50
  68. 28-06-2010, 02:29
  69. 22-06-2010, 13:44
  70. 12-06-2010, 12:36
  71. 05-06-2010, 11:35
  72. 04-06-2010, 22:43
  73. 25-05-2010, 17:06
  74. 18-05-2010, 18:58
  75. 16-05-2010, 19:26
  76. 15-05-2010, 09:31
  77. 13-05-2010, 17:02
  78. 13-05-2010, 16:51
  79. 12-05-2010, 13:04
  80. 06-05-2010, 17:02
  81. 29-04-2010, 19:56
  82. 26-04-2010, 12:24
  83. 25-04-2010, 19:35
  84. 18-04-2010, 20:13
  85. 13-04-2010, 20:03
  86. 13-04-2010, 06:16
  87. 10-04-2010, 18:48
  88. 22-03-2010, 13:48
  89. 21-03-2010, 10:02
  90. 21-03-2010, 04:21
  91. 18-03-2010, 18:57
  92. 17-03-2010, 19:27
  93. 17-03-2010, 19:08
  94. 13-03-2010, 14:20
  95. 08-03-2010, 13:05
  96. 04-02-2010, 09:15
  97. 28-01-2010, 12:35
  98. 26-01-2010, 01:08
  99. Clix
    Refback This thread
    23-01-2010, 00:02
  100. 01-01-2010, 21:01
  101. 03-12-2009, 08:02
  102. 25-11-2009, 23:10
  103. *Clix
    Refback This thread
    18-11-2009, 11:46
  104. 13-11-2009, 21:36
  105. 08-11-2009, 11:01
  106. 26-07-2009, 16:55
  107. 26-07-2009, 12:42
  108. 23-07-2009, 12:05
  109. 22-07-2009, 22:59
  110. 21-07-2009, 20:27
  111. 21-07-2009, 14:34
  112. 05-07-2009, 20:15
  113. 04-07-2009, 22:11
  114. 30-06-2009, 12:55
  115. 21-06-2009, 22:12
  116. 25-05-2009, 15:32
  117. 17-05-2009, 17:12
  118. 17-05-2009, 11:26
  119. 16-05-2009, 19:53
  120. 01-05-2009, 18:00
  121. 01-05-2009, 17:50
  122. 10-04-2009, 20:39
  123. 04-04-2009, 06:05
  124. 31-03-2009, 14:56
  125. 11-02-2009, 17:44
  126. 10-02-2009, 23:31
  127. 02-02-2009, 10:31
  128. 26-12-2008, 11:59
  129. 20-12-2008, 18:58
  130. 15-12-2008, 21:45
  131. 07-12-2008, 14:47
  132. 07-12-2008, 11:16
  133. 07-12-2008, 00:23
  134. 06-12-2008, 23:18
  135. 06-12-2008, 23:17
  136. 03-12-2008, 20:29
  137. 16-11-2008, 22:45
  138. 15-11-2008, 21:21
  139. 15-11-2008, 11:28
  140. 15-11-2008, 09:07
  141. 16-07-2008, 19:07
  142. 19-06-2008, 15:32
  143. 10-06-2008, 20:06
  144. 10-06-2008, 17:01
  145. 30-05-2008, 20:44
