Owns a white Mk3 turbo diesel with more stopping power then engine power..... boosting 0.9bar, Now De-catted!!
I've no idea TBH, don't even know what the bore is on the standard exhaust!
Great thread, alot of ye seem to know ye're stuff about td tuning..
At the moment i have a Vectra 1.7td, i have picked up a front mount intercooler for it and an N/A inlet manifold..Ive read somewhere that the n/a manifold needs to be modified??..Can anyone explain what i need to do and what else i need in order to get it up and running with the above setup.
Thanks
Sean
Hi Sean, interested to know what made you go for a N/A inlet ?Mike.
And you don't have the in-necessary filter housing bit on the top.![]()
Doesn't take long with an angle grinder and alloy wheel to dispense with that !
I need a bit of help with the induction setup for my Mk3 Astra TD.
The stock setup seems un-nescessarily long. Is there an inlet manifold that fits that just has a single air inlet on it? Or has anybody welded up the stock inlet manifold to create a solid airbox with only 1 inlet?
I basically only want 3 pipe runs - so air filter (pipercross cone) to turbo, turbo to intercooler, intercooler to inlet manifold.
Also are the head gasket sets available on ebay for £23.99 any good? Gonna rebuild the top end on my spare engine first, might port the head a bit too if I get bored.
Matt
Your current manifold will only have one air inlet.But you will have the filter housing on the top.
I personally wouldn't bother porting. Smaller ports increase the speed of the air entering the chamber which promotes more torque at lower RPM. I would only port a diesel if I was making a high-revving engine, and then why bother having a diesel engine?
Can you just block the air filter housing off then? Or chop it off completely?
Matt
Yes, chop it off. Doesn't take too long with an angle grinder.
Yeah, if you're moving the air filter then just lop it off.
Headgaskets are steel layered items, original and aftermarket should be the same (the ones i've seen were all good).
Here's an even cheaper one:http://cgi.ebay.co.uk/ISUZU-GEMINI-1...3A1|240%3A1318
What manifold is on your engine, does it have the plastic filter housing on top or is it all aluminium ?
Here's one from an early corsa, with some modifications: lmao
And what it looked like:
This is the one on later models: (this is from an n/a model, which has a single inlet on the driverside)
To fit this, you need to block the breather connection (see pic), and add the connection for the fuel pump (drill a 4mm hole, and swap or add a connection...just like in the first pic.)
Do the gaskets come in different thicknesses ?
@ Dutch Nova..The inlet i have on the car now is aluminium but it is a twin inlet, im replacing it with the n/a inlet and doing similar to what is done in the pic above.
Thanks
Sean
I found a very easy way to do this. You need a TD inlet and a n/a inlet for this one.This way you can keep the original hoses where they should be and you don't have to drill holes for the fuel pump.
- Take the bottom half of the TD inlet
- block the hole on the right (the one from where the compressed air comes in) with a little plate of metal (make sure it seals good).
- remove the metal plate that seperates the top from the bottom
- then mount the top half of the n/a inlet
'95 Corsa 1.5 D @ 1.7 TDS with an IHI RHF4
Thanks alot, sounds like a better way of doing it.
This guy is running stupidly high boost is he not?
http://cgi.ebay.co.uk/modified-corsa...1%7C240%3A1318
Hi Dutch, What effect does machining the std. flywheel , as seen on your site , have to power delivery / vibration etc. ? Thanks, MIke.
it certainly looks like an isuzu/frontera 2.8 turbo will fit this engine, as the flange mounts are the same.
Also to throw a spanner in the works, what about fitting a 1.7 16v direct injection engine in a corsa with a mechanical bosch injection pump set up to the correct opening pressures etc.
Surely the direct injection newer ones in corsa c are better than the old trusty dinosaur 8v indirect turbo model
Headgaskets come in 3 different sizes, 1.40, 1.45 and 1.50mm if you look at the picture on ebay:
there's a hole in the upper right corner, they come with no, 1 or 2 holes depending on thickness.
no hole = std 1.40mm, 1 hole = 1.45mm 2 holes = 1.50mm
The flywheels are both original and standard, the smaller one came from a 1.5, the big fat one is from a 1.7
apart from the weight and starter gear(ring) diameter they're the same.
I've only used the smaller one as it fits the F13, engine used to rev as free as a petrol one,
and as it was the original one idling, driving etc. was all fine. Only problem i had was the clutch,
it was an original 190mm plate from a 1.5D, and slipped occassionaly (when really thrashing it).
The mechanical 1.7 16V has been done, on a Y17DT from what i've heard (was in south europe),
don't have the exact details, but they got sick of pumps failing and decided to go mechanical.
I'm running a 1.7 in my Westfield and don't suffer any slipping, not really surprising given the weight. I thought about machining some of the weight off the flywheel as it truly is a massive piece of kit. Decided to run as std. at first, to see how things went. Do you know if anybody has played about with wheel weights on the 1.7 ? Cheers, Mike
