No point reving past 4k rpm due 4k being where the turbo is boosting fully ive found.
Rememeber Pop Up Headlights are the Future!
I felt I should make my presence known.
I also have one of these engines in my veccy, it's a cool engine. And I've found its relatively possible to tap your right foot along to the music, it doesn't make much differense to the driving haha.
Definately agree with the power/torque comments as well, I'm getting used to it on mine. First turbo I'm driven, let alone first diesel, so it's taken a while.
Mines goes to 4k in most gearscant beat watching the boost gauge up to 1 bar.
One of the things I love the most, is driving pretty much anywhere in 3rd and 5th
Uhoh...a bit of a tight corner...no probs, drop it to 3rd...back up to 40 back into 5th lmao
Yeh i always drive it in 3rd, and also sat in traffic i just leave it in 2nd and start off in 2nd.![]()
Oh and overtaking is so much easier, stick it in 3rd, above 2k revs and off you go.![]()
mm diesel lovin right here!!
I'm going to put mine in a vent. Going to make an MDF peice to go in the hole, or get another vent and cut the plastic so the vent retains some of it's functionality.![]()
Ill change my boost gauge holder when i can be assed, so more than likely will stay like that.
make it look like your trying get it piller mounted
Anyone know what gearbox is on the blacktop gm lump in my van, i cant find a box stamp anywhere.
Is that the small pipe on the back of the inlet manifold that goes to the fuel pump?
Actually, makes a lot of sense to t into there. I was wondering where to stick mine.
Probably about 115 - 120mph. I got mine up to 110mph and it was still pulling, but I didn't dare take it any further. I didn't fancy getting it towed back from Farnborough!
my corsa i converted from D-TD rev'd to 6,200oddi wonder one day while out with the CS lot there was a '*HUGE!*' cloud of smoke come from the back of it
it ran fine after...was a little worried somit was a miss under the bonnet though
ANDYRACER this is exactly what i was trying to tell u in my PM's for u to run the boost gauge off.![]()
Look closerit's probably an F13WR with a 3.74FDR F13 identification
(there are some 17dtl's with F15WR and a 3.55FDR out there)
Ahh cheers MM, is that also the pipe u ran the bleed valve off aswell?
Im looking to fit a boost gauge to a mates 1.5td corsa 2day.... would i be correct in connecting the t-piece to the pipe between the inlet manifold and the top of the injector pump????
cheers
To The Redline----> And Beyond--------------->
I really should read full thread first... lol
cheers
