hello hacula,
the gsi clutch will fit. it's 200 mm and the centre hole has 14 splines.
I only mention it because the engine bay will be full. If you have to change the transmission or clutch later you have to remove the transmission again.
it's a lot of work.
the f13 drives good, better acceleration.
First i used the stock intercooler of the astra. But this one was not easy to mount.
I found a cheap small intercooler on ebay. Turbo lag is little bit higher now. So if you don't want to go for verry hight performance, i recomende to put a small intercooler, the size of the original.
the intercooler is fit it as high as possible, because the bumper otherwise wil not fit.
i removed some metal undernead the headlight to route the pipes.
i only put a k&n filter because the original air filter wil heat when the engine is hot.
i put the hole in the bumper because the engine get to "hot". Driving on the highway at 4000 rpm/150 kmh get the engine at 100 °C.
I also drive on veggi oil, so the engine temp goes a littel bit hotter then normal. Maybee you don't have any problem if you drive it stock. Also, the combo ( van ) will weigth a little more than a corsa.
if you have the room and time, you can put an extra oil cooler.
