Originally Posted by
RickGTE16V
ok kristof , thats the easiest seal to replace without dismantling the pump so your lucky , i got mine from a specialist diesel place , cost about 20 quid , say you want a seal kit for bio diesel / veggie oil , i cant remember the name of the company i bought mine from but if i do ill let you know , as for replacing it its like an o ring , you will need to disconnect the injector pipes and then youll see 4 star head bolts holding the end of the pump on , now under that end are springs and lots of small moving parts so be afraid , very afraid , anyway loosen the star bolts but DO NOT TAKE THEM ALL THE WAY OUT , until you can just ease the end of the pump out by about 8 mm , then you will be able to see the o ring , just cut it with a stanley knife then pull it out from its grove , then to fit the new one , cover it in grease and stretch it over the back of the pump and take one bolt out , slip the o ring past it and refit the bolt , one at a time so you do not withdraw the pump head any more than 8 mm or so away from the body , if you pull it too far the peices inside will fall outof place and your in for a nightmare , then after the ring is past all the bolts , seat it into the groove and gently tighten the pump head back down , make sure it seats sqaure , do each bolt a few turns at a time cos if you get the head back on off sqaure you will break the plunger too ( ive done this also) , just be careful , slow and make sure everythings clean and youll be alright , put your pipes back on and woohaa leak fixed - now your a diesel mechanic
