Page 14 of 61 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 ... LastLast
Results 326 to 350 of 1504
Thread: Isuzu turbo diesel tuning guide
  1. #326
    Nov 2008
    Midland
    Re: Isuzu turbo diesel tuning guide
    Sweet, gonna do that tomorrow then! I've only got to tune the engine as the exterior, interior, ice etc are fully modded, what else could i do to the engine?
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Service it!
    I need to get some reconditioned injectors.
  4. #328
    Nov 2008
    Midland
    What will that achieve?
  5. #329
    Mar 2006
    West Country, UK.
    Corsa B 1.7TD
    Have you checked the valve clearances ?
    The Isuzu engine has a tendancy to wear valve seats and so the clearances get tight, I have noticed a big difference when the clearances are adjusted correctly compared to when they were tight.
    If you have not checked/adjusted them it would be worth doing before tweaking the fuel/boost as it will have an effect on how the engine runs and how much fuel is needed.
  6. #330
    Dec 2005
    UK
    Quote Originally Posted by cavalierkc View Post
    Better spray pattern, more atomisation. Instead of just squirting the fuel as a jet and having it sitting on top of the piston in a puddle. lmao
  7. #331
    Nov 2008
    Midland
    Fitted my boost valve and got it to run smoke free at 0.97BAR. Hows that sound? can i up any more boost? Goes like a rocket now...
  8. #332
    Nov 2008
    Midland
    Quote Originally Posted by duckruls View Post
    What are they? and where are they?
  9. #333
    Mar 2006
    West Country, UK.
    Corsa B 1.7TD
    Valve clearances are the gap between the valve and the camshaft, they tend to be neglected as they need shimming if incorrect, worth checking and if there tight definately worth getting adjusted.
    Around 1 bar boost pressure is good in my opinion if you want reliability, they seem to run up to 1.5 bar without problems going by what i have read on the net but it will depend on if you want to take the chance on it going bang lmao
    I have had mine boosting at 1.5 bar but I decided that as an every day car it was not worth the risk and now have it at 1 bar.
  10. #334
    Nov 2008
    Midland
    Where do I start? I'm learning all my knowledge of here so to do the work myself, working so far....any pics on what to do?
    oh my clocks i bought only give a readout up to 20PSI / 1.4BAR
    Have you got a picture of your car? would like to see it?
    Heres mine...
    http://www.migweb.co.uk/gallery/show...php/photo/5547
  11. #335
    Mar 2006
    West Country, UK.
    Corsa B 1.7TD
    Nice car
    You should get yourself a Vauxhall/opel diesel engine haynes manual, its well handy for engine DIY jobs, if you keep a watch on ebay they come up for under £10 every now and again.
  12. #336
    Jan 2008
    Moray NE scotland
    Cavalier SRi c20xe
    I have got myself a astra estate 1.7td as a cheap run around. When changing the air filter I found that there wos no safety valve in the mainfold, dose that mean that the safety valve is someware else. As i wos wanting to turn the fuel and boost up on the engine.
    Greig
  13. #337
    Oct 2008
    London UK
    Do you definatly have the isuzu engine Greg?
    It may be the GM one in which case you can't tune it.
  14. #338
    Sep 2004
    Hants/Beds
    've run 1.5 bar on my 1.7td corsa for a year now and its been fine it made 116bhp and 175lbft but it has had some tweaks
    Enjoy!
  15. #339
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Count-Can you list your mods?
    Fuel pump played with
    Boost wacked up
    FMIC
    Anything else????
    1116hp and 175 lb/ft is bloody impressive!
  16. #340
    Sep 2004
    Hants/Beds
    Quote Originally Posted by LongLiveTheNova View Post
    That would be impressive!
    As for mods...
    1.7 td from a cav known mileage as a base
    White polo mod
    Upped fuel
    upped boost
    FMIC with custom pipework and N/A manifold
    Full stainless exhaust system from turbo
    Cone filter to turbo
    Thats it i think, it made that power in a RR day for total vauxhall
  17. #341
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Woops, one too many 1's there lmao
    Cool, not a huge amount of stuff then for the gains.
    Does the NA manifold go straight on?
    Edit-Found the vid of the run that i got Nice
  18. #342
    Sep 2004
    Hants/Beds
    No not really, i forgot to mention that was running 1.2 bar and less fuel than it is now as the operator on the day suggested i raised it so should be more like 120bhp now and nearly 200lbft!
  19. #343
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Will have to have a play with my td runabout lmao
  20. #344
    Sep 2004
    Hants/Beds
    Do they go like funk! Shame i have sold it to my dad now...got a mk3 astra estate 1.7td now what form of td have you got....nova?
  21. #345
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Will have a mk3 astra
  22. #346
    Sep 2004
    Hants/Beds
    John H? good choice imo
  23. #347
    Jan 2008
    Moray NE scotland
    Cavalier SRi c20xe
    Quote Originally Posted by Fridge View Post
    Its the isuzu engine but it dose not have the safety valve under the air filter. Didnt want a car with the gm engine. Took me a wile to find a suitable car. The last couple of days it has been very cold and its not keen to start, fitted new glow plugs and made sure there are getting power. Need to check the cold start setting on the pump and the shims next, if thay are ok im stumped. Need to get it running as it should before i turn up the boost and fuel.
    Greig
  24. #348
    Dec 2005
    Telford
    astra TD Tuned
    had the same problem with mine with cold starting, had it fully serviced, 2 sets of brand new glow plugs later, fuel filters, new battery, still the same, changed the relay under the bonett, starts first time everytime! think its the relay for the plugs or something, cost about £8 iirc
  25. #349
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    Quote Originally Posted by count vaux alot View Post
  26. #350
    Dec 2008
    kettering, northants
    1995 corsa b
    hi all. I have done all the mods on this page to my satin black rat look 1994 corsa 1.5 TD.
    I have fitted a rev counter to my car with a shift light. I have wired it to the green wire on the back of the alternator. is this right as it is over reading alot ( just under 6000 rpm ) and goes well off the clook when you tap the throttle. this car is used for drag racing ( back in black racing ) best time 14.93 @ 87 mph. so I do need to keep a eye on the revs and the shift light will help us get the gears right for the best time.
    also I would like to fit a much biger intercooler. what car is best to get one from that will not cost to much ?
  1. 10-02-2012, 08:51
  2. 05-02-2012, 17:34
  3. 26-01-2012, 11:58
  4. 17-01-2012, 09:43
  5. 13-01-2012, 01:44
  6. 30-12-2011, 02:52
  7. 10-12-2011, 22:43
  8. 10-12-2011, 22:02
  9. 06-11-2011, 20:24
  10. 21-10-2011, 14:56
  11. 19-10-2011, 19:29
  12. 18-09-2011, 14:04
  13. 12-09-2011, 09:08
  14. 11-09-2011, 12:25
  15. 01-09-2011, 21:23
  16. 29-08-2011, 17:55
  17. 25-07-2011, 00:02
  18. 17-07-2011, 22:16
  19. 15-07-2011, 01:24
  20. 06-06-2011, 18:05
  21. 01-06-2011, 20:03
  22. 28-05-2011, 16:33
  23. 28-05-2011, 16:33
  24. 19-05-2011, 23:38
  25. 19-05-2011, 16:50
  26. 13-05-2011, 23:35
  27. 03-05-2011, 12:38
  28. 29-04-2011, 21:00
  29. 22-04-2011, 05:09
  30. 16-04-2011, 08:23
  31. 12-04-2011, 19:35
  32. 11-04-2011, 19:37
  33. 09-04-2011, 09:47
  34. 29-03-2011, 21:15
  35. 16-03-2011, 18:46
  36. 27-02-2011, 09:49
  37. 18-02-2011, 18:20
  38. 10-02-2011, 23:39
  39. 06-02-2011, 11:06
  40. 05-02-2011, 20:42
  41. Isuzu
    Refback This thread
    03-02-2011, 20:47
  42. 18-01-2011, 12:12
  43. 12-01-2011, 22:45
  44. 12-01-2011, 20:03
  45. 12-01-2011, 19:38
  46. 04-01-2011, 12:50
  47. 27-12-2010, 11:57
  48. 23-12-2010, 13:33
  49. 18-12-2010, 16:11
  50. 24-11-2010, 11:42
  51. 18-11-2010, 22:41
  52. 18-11-2010, 21:49
  53. 05-11-2010, 04:57
  54. boost
    Refback This thread
    05-11-2010, 00:10
  55. 04-11-2010, 01:20
  56. 03-10-2010, 18:12
  57. 03-10-2010, 17:41
  58. 26-09-2010, 04:28
  59. 14-09-2010, 20:12
  60. 07-09-2010, 22:16
  61. 31-08-2010, 18:04
  62. 30-08-2010, 20:12
  63. 24-08-2010, 21:55
  64. 15-07-2010, 01:54
  65. 14-07-2010, 23:04
  66. 12-07-2010, 19:52
  67. 06-07-2010, 12:50
  68. 28-06-2010, 02:29
  69. 22-06-2010, 13:44
  70. 12-06-2010, 12:36
  71. 05-06-2010, 11:35
  72. 04-06-2010, 22:43
  73. 25-05-2010, 17:06
  74. 18-05-2010, 18:58
  75. 16-05-2010, 19:26
  76. 15-05-2010, 09:31
  77. 13-05-2010, 17:02
  78. 13-05-2010, 16:51
  79. 12-05-2010, 13:04
  80. 06-05-2010, 17:02
  81. 29-04-2010, 19:56
  82. 26-04-2010, 12:24
  83. 25-04-2010, 19:35
  84. 18-04-2010, 20:13
  85. 13-04-2010, 20:03
  86. 13-04-2010, 06:16
  87. 10-04-2010, 18:48
  88. 22-03-2010, 13:48
  89. 21-03-2010, 10:02
  90. 21-03-2010, 04:21
  91. 18-03-2010, 18:57
  92. 17-03-2010, 19:27
  93. 17-03-2010, 19:08
  94. 13-03-2010, 14:20
  95. 08-03-2010, 13:05
  96. 04-02-2010, 09:15
  97. 28-01-2010, 12:35
  98. 26-01-2010, 01:08
  99. Clix
    Refback This thread
    23-01-2010, 00:02
  100. 01-01-2010, 21:01
  101. 03-12-2009, 08:02
  102. 25-11-2009, 23:10
  103. *Clix
    Refback This thread
    18-11-2009, 11:46
  104. 13-11-2009, 21:36
  105. 08-11-2009, 11:01
  106. 26-07-2009, 16:55
  107. 26-07-2009, 12:42
  108. 23-07-2009, 12:05
  109. 22-07-2009, 22:59
  110. 21-07-2009, 20:27
  111. 21-07-2009, 14:34
  112. 05-07-2009, 20:15
  113. 04-07-2009, 22:11
  114. 30-06-2009, 12:55
  115. 21-06-2009, 22:12
  116. 25-05-2009, 15:32
  117. 17-05-2009, 17:12
  118. 17-05-2009, 11:26
  119. 16-05-2009, 19:53
  120. 01-05-2009, 18:00
  121. 01-05-2009, 17:50
  122. 10-04-2009, 20:39
  123. 04-04-2009, 06:05
  124. 31-03-2009, 14:56
  125. 11-02-2009, 17:44
  126. 10-02-2009, 23:31
  127. 02-02-2009, 10:31
  128. 26-12-2008, 11:59
  129. 20-12-2008, 18:58
  130. 15-12-2008, 21:45
  131. 07-12-2008, 14:47
  132. 07-12-2008, 11:16
  133. 07-12-2008, 00:23
  134. 06-12-2008, 23:18
  135. 06-12-2008, 23:17
  136. 03-12-2008, 20:29
  137. 16-11-2008, 22:45
  138. 15-11-2008, 21:21
  139. 15-11-2008, 11:28
  140. 15-11-2008, 09:07
  141. 16-07-2008, 19:07
  142. 19-06-2008, 15:32
  143. 10-06-2008, 20:06
  144. 10-06-2008, 17:01
  145. 30-05-2008, 20:44
