Everything is inter-related, without increasing the fuel you will struggle to get extra boost.
The max fuel screw increases the fuel across the whole rev range including when on full boost and the boost compensator is in operation.
It took me a couple of hours to setup, I disconnected and blocked the wastegate pipes and the boost compensator pipe, then I adjusted the max fuel screw until it would take full throttle from low revs without a puff of smoke when planting the throttle.
Next I connected everything back up and adjusted the boost controller until it was boosting at a steady 1 bar in all gears, then lots of accelerating in different gears and speeds checking for smoke, if it smokes turn down the max fuel screw if it does not smoke turn it up, I've set mine so that it barely smokes as I don't like it putting out a smoke screen when accelerating.
If you want to try some more in-depth stuff you can rotate the boost pressure compensator which will increase/decrease the fuel when on max boost only (but make sure you mark it first so you can get back to the standard position), you can also adjust the spring under the diaphram as this controls the amount of boost needed for the extra fuel to be added.
Here's a link to a very interesting article on mechanical diesel tuning, slightly different pump but the principles are the same, its worth reading all of the articles on the peugeot project car as they explain how to improve the performance of the diesel (exhaust/induction/fuel/boost):
http://autospeed.com/cms/A_109345/article.html
There's a 2.4 too.
