HELP! turbo conversion help needed
Results 1 to 22 of 22
Thread: HELP! turbo conversion help needed
    Kent
    X Astra GSi Turbo ow
    Unhappy HELP! turbo conversion help needed
    Ok i got the turbo engine in my Astra Gsi now, everything is sorted apart from the wiring!
    Ive sorted the starter motor loom which is now attached to the car loom.
    Anyone know why i dont have a red/blue wire for the fuel pump?
    Also i have no spark, yes i have conected up the black wire to the coil, and that to ignition supply.
    Any help would be much appreciated. Or if anyone in the Kent area is a good with this sort of thing, and wants to give me a hand that would be great too, obviously a drink or two or three is included
    UK
    Cav turbo and XJR
    The first plug. Does it have a black wire ? If so it's the ignition supply to the engine loom and needs connecting.
    The second plug looking like a TC control plug betweeh the engine loom and car loom ? is this right ? You removed your old loom.
    Also read this.
    Wiring cav engine into astra mk 2
    Kent
    Thread Starter
    hehe i knew you would come to my rescure Mr AndyK
    yes the wire is black - so i can just connet it to the battery, or does it need to go to a live, for just when the ignition is on?
    yes i removed my old engien loom.
  5. Remove Advertisements
    UK
    Cav turbo and XJR
    It needs to goto the ignition supply.
    live only when ign on.
  7. #5
    Kent
    Thread Starter
    thanx
    any other gen on the rest of it?
    On the large plug (pic D) some of the wires on here colour match the wires on the green and black turbo loom plugs.
  8. #6
    Sep 2000
    Near Stirling
    10s Evo VI,12s Astra
    Looks a bit like a the diagnostic plug.
  9. #7
    Kent
    Thread Starter
    the diagnostic plug is in the fuse box
    i checked the voltages,( pic D ) one end is an earth, and oposite (yellow wire) is live when the ignition is on. the rest have ifferent voltages from 2.8v right back up to 12v.
  10. #8
    Kent
    Thread Starter
    come on guys, someone must of done one of these before.
    anyone know what has haopended to NotNormal, ive emailed him and sent text msg, but no answer.
  11. #9
    Kent
    Thread Starter
    bttt
    plllllllleeeeeeeeeeeeaaaaaaaassssssseeeeeeee
    help me, ive been on this for 2 days, and cant figure it out. can some1 help?
    i have no fuel pump buzz and no starter motor click
  12. #10
    MIGWeb User ChrisReay's Avatar
    May 2001
    Durham
    Meriva/Insignia VXR
    Can you post the colours of the wires your having trouble with?
  13. #11
    UK
    Cav turbo and XJR
    Have a look at this document which I just wrote which lists the pinout of the cavalier ecu loom interface connectors.
    Cavalier ecu connections
    For me to help you any more I need to know the wire colours on the astra loom.
  14. #12
    Kent
    Thread Starter
    Ok i pretty much sorted, the plug on pic "D" is not used so i can leave that.
    i have connected the black wire to the + on the coil and then run a wire to an ignition feed.
    everyone has been telling me about the two pin plug with the red/blue wire for the fuel pump. for some reason or other my turbo loom does not have this, i have checked along the loom and it hasn't been chopped. Does anyone know how thick this red/blue wire is???
    On the fuel pump relay i have a white/balck(thin) wire & a red/blue wire(thick) going into the same pin, i put a metre at this point and it has a permant 12v going to it, is this right
  15. #13
    May 2001
    Durham
    Meriva/Insignia VXR
    The black/white wire is for the heater in the lambda sensor, the thicker red/blue wire is for the fuel pump eventually.
    Can you trace the red/blue up into the engine harness? It should just loop back down to a the 2 pin black plug (maybe 15-20 cm up)
  16. #14
    Kent
    Thread Starter
    ok so if im looking at the red/blue wire, it goes from the two pin plug and goes back into the fuel pump relay? and the other end of the two pin plug goes to the fuel pump fuse?
  17. #15
    May 2001
    Durham
    Meriva/Insignia VXR
    Yes.
  18. #16
    Kent
    Thread Starter
    ok i have done the above and still no joy, i have two fuel pump relays, is it possible i have buggered both trying to get them to work?
    im testing the relays on a mates car tomorow
    btw does the lambada sensor get hot, when the ignition is on?
    once i have sorted the fuel pump, i need to sort out why i have no spark
  19. #17
    May 2001
    Durham
    Meriva/Insignia VXR
    I think your problem may be your ignition live, you say you've connected the black wire to the coil +, By this do you mean on the actual coil cylinder? remove if you do. The black wire only needs connecting to an ignition live.
  20. #18
    Kent
    Thread Starter
    the black wire i have going to the coil +
    then i have another wire on the coil + that goes to the ignition.
  21. #19
    May 2001
    Durham
    Meriva/Insignia VXR
    disconnect both wires from the coil and join to each other.
  22. #20
    Kent
    Thread Starter
    thanx
    should there be any wires comming from the coil + because it has like a spade type connector on it
    i will go do that now
    any other ideas if this does not also solve the problem?
  23. #21
    May 2001
    Durham
    Meriva/Insignia VXR
    You have a multimeter?
    The black plug that's plugged in to the ignition module by the coil, if you peel back the rubber boot on it and check for 12v on the black wire with ignition switched on. Do the same for pin 27 on the ECU connector in the car, looking for 12v again.
  24. #22
    Kent
    Thread Starter
    ****ING YES YES YES !!!!!!!
    IT RUNS!!!!!!
    i have the black wire which goes to the coil which then in turn goes to the ignition.
    I have discovered that it helps if you conect the power supply for the ECU to the + and not the -
    Many thanx to everyone who helped me today!!
    have a on me
    Thankyou
    .......right im off to race some cossies
