Hi
We have just put a redtop engine in to a 1995 calibra 2.0 ecotec. Calibra had the early ecotec engine.
When we turn they key to start the car, the engine turns but it appears no fuel is pumped into the injectors. In turn, the car wont start?. Any ideas
We have also noticed when ignition is on, it sounds like the injectors are turning on and off pretty fast
Could there be an issue with the built in alarm? How can we buy pass the original immobiliser if it's still active after swapping engine out with a redtop along with ECU?
Thanks
James
Thanks
James
