my c20ne is being fully re-built at the mo, i have had a few mods done so far, including a re-bore, new bigger pistons (only 1mm bigger!) fully balanced, lightened and balanced flywheel etc, now its come to the head im getting a bit confused and stuck! i have had the head stripped and dipped in acid and skimed, i was then going to fit my kent cam (sport r). i got the cam out of another 8v and its only done 1500 miles, but do i need new rockers etc? and if so where to get them from? im just a bit confused when it comes to the head, im a bit of a newbie to this tuning malarky! any advice/suggestions would be really helpfull!
ive thaught about maybe new injectors but not sure if its possible on the c20ne and what other work will be involved after fitting them? will it need an ecu remap?
