Intercoolers on N/A engines is...
Results 1 to 14 of 14
Thread: Intercoolers on N/A engines is...
    Aug 2001
    Swindon, Wiltshire
    Astra J VXR/Ampera
    a bad idea if i remember coz this was discussed a while ago?? Cant find the thread u see
    Scotland
    Saab/Pug/Zaf
    there aint much point cooling air with air when its all at the same pressure and temp
    Northeast Kent
    yes bad, it would be like me or you trying to breath through a macdonalds straw. the point of cooling a turbo charge is cause the turbo heats the air immensely. N/A inlet charge is atmospheric temp already.
  5. Remove Advertisements
    Aug 2001
    Swindon, Wiltshire
    Astra J VXR/Ampera
    Thread Starter
    cool. Just checking
  7. #5
    Mar 2002
    Fife
    No longer a RS Turbo :)
    wot about a chargecooler tho??????????
    Nova 1200 16vready
    cavvy Sri
    honda civic bucket of purple poo
  8. #6
    Jan 2002
    Cirencester
    MK4 Astra 1.6 SXI (Z16XE)
    think u would also find that it would be restricktive to a certain extent so loosing power, also the longer inlet track would loose throttle responce
    bad idea really
    Stu.
    2 stroke tarmac terrorist
  9. #7
    Scotland
    Saab/Pug/Zaf
    yeah, you could always cool 20 degree air with 90 degree coolant
  10. #8
    Northeast Kent
    youre are missing the point here, all an intercooler and charge cooler does is reduce inlet charge to as near to atmospheric temperature as it can. N/A engines already draw in air at outside temperature.
  11. #9
    Mar 2002
    Fife
    charge cooler off seperate water source to engine with scooby stylee IC spray
    gotta be worth at least a tenth of a bhp on a n/a motor
    Nova 1200 16vready
    cavvy Sri
  12. #10
    Oct 2001
    Kent
    the car in front
    Re: Intercoolers on N/A engines is...
    Man, it would look kewl.
    A dump valve (or equvalent noise generator) would be even cooler.
    A large wing at the back (no need for it to be functional), as well as grossly flared arches to accomodate 19" wheels.
    Believe it or not, all the above have been debated time and again by people struggling to impress without shelling out for a proper car!
  13. #11
    Aug 2001
    Swindon, Wiltshire
    Astra J VXR/Ampera
    Thread Starter
    did i say i was going to fit 1?
    NO
    Some1 at work was asking if it worked or not - he didnt believe me when i said it wouldnt work, and as i couldnt find the thread about it, i thought id ask.
    is that ok with u john A
  14. #12
    Northeast Kent
    dont worry about john, hes just more pecemistic/sarcastic than me and 16vastra added together.
  15. #13
    Scotland
    Saab/Pug/Zaf
    doubt it
  16. #14
    Oct 2001
    Kent
    the car in front
    NO
    Did I say you were?
    NO
    lmao
