Just wondering whats available (if anything) for a 1.8SEH 8v.
Currently the power should be around (IIRC) 112BHP and 110lbs Torque so with a turbo attached (with all the necessary additions etc) what power could I expect. Obvisouly this is a bit of a 'string long how' question but with the masses of brainpower on here I hope someone can give me a rough idea.
You know I've never got the hang of the engine code lol. I do know its suppposed to come with the slightly more powerful of the two 1.8 engines. Would that be the SE?
Reason for asking the initial question is that I want turbo power but don't see the LET materialising anytime soon. So wondered what the reality of a 1.8 Turbo would be seeings as I've got a 25K mile engine as a starting point.
As has been mentioned already, Matheus at Mvaux would be able to supply a kit. The 2L manifold will fit the 1.8L (the exhaust ports are the same).
Because of the high compression I would recommend the following:
1. Remove pistons and machine the crown to a bowl diameter of 69mm by 5.5mm deep. Make sure there is a radius at the bottom of the bowl. This should give a compression ratio of 8:1 with the standard head gasket. Alternatively, if the engine is tired you can buy replacement turbo pistons (8:1) from Sealed Power. Part numbers are 503NP for stock size and 503NP.50MM for (you guessed it) 0.5mm over pistons. You should be able to order these from any of the american parts suppliers here in the UK. There application is for the US turbo 1984 PONTIAC J2000/SUNBIRD 4-112 1.8L.
2. Get a good intercooler.
3. Get a boost referenced ignition retard device, either MSD or a UK company called Microdynamics.
4. Do some calculations to make sure your injectors can supply enough fuel. May also be a good idea to fit a fuel pump from a XE or LET Cav/Calibra. Get a fuel pressure gauge too, you'll need this to set up the fuel injection base pressure.
5. The most important thing is to get it set up properly on a rolling road so you don't get any knock/detonation - this will quickly destroy your pistons, big ends, etc.
The modified stock/Sealed Power pistons will support up to 250hp if you don't get any knock. 10-15psi with good intercooling will see you over 200hp and possibly up to 230-240hp.
Other advice: 2.5" exhaust minimum. Keep the intercooling pipe work as short as you can (helps "lag"). Don't buy a ****ty stainless steel or the latest multicoloured foam air filter off ebay, get a good quality one e.g. K&N. Don't mount the air filter in the engine bay if at all possible, hot air into a turbo equals even hotter air out of a turbo and more chance of knock/detonation.
Would be pretty easy to see about 160bhp without many major changes IMHO
