Crank pulley bolt size, is it E20?
Results 1 to 12 of 12
Thread: Crank pulley bolt size, is it E20?
    Apr 2002
    Southwest
    Like its stolen
    Cant remember off hand and need to advise someone on what tool to get.
    can anyone remember the exact size of the crank pulley bolt, i think they are the same for all years?
    Its the BIG bolt in the center of the pulley that goes into the crank that im referring to.
    Mar 2005
    Anglesey<>Manchester
    BMW, Corsa B XE
    Not sure on all engines, but the C20XE is E20
    Apr 2002
    Southwest
    Like its stolen
    Thanks mate.
    If anyone else can confirm or deny it would be helpful just to be sure
    Jul 2000
    Its E20 for sure.
    BRB
    Apr 2002
    Southwest
    Like its stolen
    Thanks honey bunny
    Jul 2000
    No problem pumpkin x
    BRB
    Jun 2000
    Swindon
    remember the bolt is heavily shouldered for strength - a flat faced E20 socket will likely slip off and cause you to lacerate your wrist against the rusty oily lower crossmember, so, unlike me, try to avoid seeing all the bits that make your hand work, and find a shouldered socket to match.
    Apr 2002
    Southwest
    Like its stolen
    Engine is sat on CP's bench, not an oily cross member in sight
    MIGClub Member wayne451's Avatar
    Jan 2005
    The Internet.
    Mods round the bend...
    I know its already confirmed but its definately an E20 as they don't come on the Halfrauds rail and I had to buy mine seperately!
    Warren Buffett.
    Jun 2000
    Swindon
    bet I could injure myself, even if it meant cartwheeling backwards out a window, narrowly missing a pick up truck full of cushions.
    Apr 2002
    Southwest
    Like its stolen
    Gary, im sorry you felt i was underestimating your ability to self harm.
    Especially with things like a combine harvester within staggering distance if you lean forward to quick and stab your eye out on the dipstick and wander out the workshop door in a painful daze as Charles is pottering past in one.
    MIGWeb User Add_Gee's Avatar
    Mar 2002
    Birmingham
    Vectra B SRi 2.2 Estate
    E20? pah... 16mm socket will be fine...
    (Edit, only joking by the way... expected to get ripped..no one took the bait)
