Code 41 Speed Ident Sensor. What The Hell?????
Results 1 to 8 of 8
Thread: Code 41 Speed Ident Sensor. What The Hell?????
    May 2001
    Workville Ipswich
    BTCC cav & LET Corsa
    eerrrrrm last night me and tufty were in his veccy turbo C20LET MOTRONIC 2.7and the ecu light came on....... he quickly checked the code and it was 41.............. which is a bit strange as according to the code list, it does not have a code 41.......... any ideas anyone......... apparantly 41 is the speed ident sensor.......... we presumed it would be the crank shaft sensor can think of anything else but thought it would be a good idea to ask on here........????????
    May 2001
    Workville Ipswich
    Thread Starter
    BTTT......
    ANDY K, RDS, SAVAGE...........ANYONE ?????
    Aug 2001
    Location Location
    Audi
    I think you'll find that it is the "1st gear Ident Switch."
    This may mean that the wire that senses first gear on the box has come off / is broken.
  5. Remove Advertisements
    May 2001
    Workville Ipswich
    Thread Starter
    OK NICE ONE MATE CHEERS
  7. #5
    May 2001
    Workville Ipswich
    Thread Starter
    JUST PHONED AND SPOKE TO TUFTY AND APPARANTLY THAT SENSOR IS ON A DIFFERENT CIRCUIT, NOT THE ENGINE CIRCUIT...... AND IT DONT LIST IT SOR A TURBO ENGINE......SO ITS STILL A BIT OF A MYSTERY
  8. #6
    Aug 2001
    Location Location
    Audi
    Toby - have a look at this:
    Management code 42 ??HELP??
    I know it refers to 42 but it may still be of use.
    Also have a look at this:
    http://www.akirwan.freeserve.co.uk/akhow2/diag_no2.rtf
  9. #7
    Aug 2001
    Location Location
    Audi
    I would have thought that it would be connected to the Engine circuit bearing in mind the sensor is there to control the boost in first gear (I think).
  10. #8
    near Glasgow....
    BMW 540i....
    Find the wire at the front of the gearbox (near bottom) and make sure its attached correctly and that the wires aren't cut etc.
    If you like you can cross the wires together to remove this limit and see if this helps.
    The Cav-Turbo Resource:
    Click Me
