right guys need some help here, having trouble doing the oil seals on an f20 box, its in situe got the long shaft side one out as its on a removable plate, the one in the huge castle nut side i cant lever out, does it need to be pressed out?
tried installing a new one to the removed side and totally buggered the seal lips, even with a suitably sized tool (an old bearing shell)
