I have recently bought a cavalier turbo (year 1994) & have a few things that need sorting:-
1) I have a Blitz SBC dual-solenoid digital boost controller. When boost is turned completely off, the car runs fine and revs perfectly, but once you start turning the boost up and hit the turbo, most of the time the car splutters.
2) When the car is warming up and idling, quite a lot of blue(ish ) smoke puffs out , once car takes off, the smoke clears and no more is seen until car slows down i.e. at traffic lights, parking up, etc.
3) And if that’s not enough….. 4x4 doesn’t work. When I put the fuse in for the 4W drive power steering fluid pours out of a breather pipe, any suggestions?!
Any information you may have on the above problems would be very much apreciated!
