its an R reg. there are 4 engines the same spec as far as i can pick up. DHA,DHB, DHC and DHD.
unsure which it is but i assume there isnt much difference between then
anyway the problem is that randomly it'll cut out for a split second then just keep going. does it whether you are accelerating or decellerating. also noticed that the rev counter dips when it does it. kinda like somwone has cut the ignition for a spilt second. rev counter heads straight for zero.
any ideas folks? its been at a garage and they cant find anything. checked all connections etc. they say the best thing that can happen is for it to break down totally then they can fix it. i say prevention is better than cure
rodgerq
rodgerq
