Has my head gasket gone?
Results 1 to 13 of 13
Thread: Has my head gasket gone?
    Mar 2004
    Wrexham
    Nova LET & Focus RS
    There is a build up of browish mayonaisey sludge in my header tank, the car still runs fine doesnt smoke or use any oil, the oil on the dipstick and near the filler cap looks fine.
    could it be that the head gasket has gone for a previous owner and there is still a load of ****e in the engine which the water is picking up?
    The car hardly gets used and have just noticed th sluge tonight after not using the car for 2 weeks.
    cheers for any help
    Oct 2005
    South London
    Vectra VXR
    could be pourous head
    MIGWeb Moderator
    Midlands
    Nowt
    Try flushing the coolant for starters
    Dec 2005
    Lossiemouth, NE Scot
    carlton gsi3ltr
    there is still heads out there that are mixing.
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Does it lose water?
    They're there, in their room.
    Mar 2004
    Wrexham
    Nova LET & Focus RS
    Quote Originally Posted by Astra Dan
    Does it lose water?
    Doesnt lose any
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Any pressure in the header tank?
    Mar 2005
    Anglesey<>Manchester
    BMW, Corsa B XE
    Does it lose water?
    If its a porus head, the coolant level will rise slowly as the oil is under higher presure than the water and is forced in through the crack.
    Read up here for some info on 'porus' heads
    As paul says, first thing, clean the coolant system and run the car for a while, maybe a week or so of driving it. If it comes back you will need the head off for inspection. If the gasket looks fine it could have cracked and will need repairing
    Mar 2004
    Wrexham
    Nova LET & Focus RS
    not much but havent really let it get to the point where its hot
    Dec 2005
    carlton gsi3ltr
    Quote Originally Posted by Paul
    i had to do this 1ns a week till i got mine done filled the bottle every time if you flush it and it reapears this will give you idea.
    Mar 2004
    Wrexham
    Nova LET & Focus RS
    well I recently fitted brand new silicon hose kit and bailey header tank with a new coolant then? so looks like head is porous ?
    the header tank is now caked in sludge
    cheers for the info too
    Nov 2005
    altrincham N/WEST
    supra 3.0i / gsx600f
    smell the header tank and if u smell petrol then ur looking at head off job i can do it for u pm if interested
    gpollen1@hotmail.com
    Mar 2005
    BMW, Corsa B XE
    Taken from: http://topbuzz.co.uk/info/porous_heads/porous_heads.htm
    Some users have put a small amount of washing up liquid in the coolant tank. The cleaning agent in the washing-up liquid cleans the oil veins more efficiently than water can, hence it basically flushes out the head, and then dumps it back in the coolant tank.
    Makes sure your car keeps on cooling its self till you get it fixed....
