HELP!! STD XE piston pics needed
Results 1 to 10 of 10
Thread: HELP!! STD XE piston pics needed
    Feb 2002
    London
    1992 Calibra Turbo
    I have just spoken to someone regarding pistons, and basically they can supply me with forged XE pistons, machined with to give low comp. They use the XE pistons as it had a thicher crown than the turbo, can anyone confirm this>?
    Northeast Kent
    picture wont confirm anything.
    so are they saying a machined early XE piston is still thikcer than normal LET piston.
    Feb 2002
    London
    1992 Calibra Turbo
    Thread Starter
    yup....but im sure the dimentions are different...im trying to get hold of a mahle distributor myself, i`ll just buy the turbo ones and have them machined.....i cant afford high prices that some ppl are charging for pistons....i`ll prolly go about 450 max!
  5. Remove Advertisements
    Mar 2001
    Chelmsford, Essex
    Redtop Westfield
    If you're after forged Mahle XE's you're out of luck, they wont make them unles you order 500 or something. They only do cast ones now!
    I'll have a look at the Mahle catalogue to see what the differences are between XE and LET. But to me it sounds unlikley that you would be able to machine a std XE enough to the low comperssion ratio you want. Could be wrong though.
    I work for Ford, and I still wouldn't buy one!
  7. #5
    MIGWeb User ChrisReay's Avatar
    May 2001
    Durham
    Meriva/Insignia VXR
    ACCRALITE FORGED
  8. #6
    Feb 2002
    London
    1992 Calibra Turbo
    Thread Starter
    hey yeah, thats who make the courtenay pistons!! and they do them for the turbo too!! i shall try and find out more....
  9. #7
    May 2001
    Durham
    Meriva/Insignia VXR
    James Lister & Sons
    I think you may get a good price from this company,
    For Accralite Pistons
    Tel (0121) 525 6450
    Fax (0121) 553 5951
    Email pistons@accralite.com
    Worth a try!
  10. #8
    Feb 2002
    London
    1992 Calibra Turbo
    Thread Starter
    yup just spoken to them, they are 105, about 45 cheaper than courtenay.. and the only problem is that they wont be done till 10th of june!!!!!!!!!!!!!!
  11. #9
    near Glasgow....
    BMW 540i....
    Any real diff between accralite and mahle pistons ??
    The Cav-Turbo Resource:
    Click Me
  12. #10
    Feb 2002
    London
    1992 Calibra Turbo
    Thread Starter
    well im in a tough dilemma, the forged accralite one as used by courtenay are 105 so about 420 for a set inc rings etc...Gav wants 525 for a set of mahle which are drop forged, but will be machined for lower compression....so do I buy the mahle ones from gav or do i wait for the accralite ones?
