I'm no expert, but I do know the inlet manifold won't fit (the later style) under the bonnet, so you'll need to use you "C" stuff. Otherwise it should all be fine.
I was going to use all the existing ancilliaries and fit a X25XE or X30XE engine, but just wanted to know if this is possible.
Also i know i have to use existing sump and manifolds, can i use teh existing ECU and loom and gearbox?
i put x25xe in mine after botton pully came loose and slipped timin in my c25xe. since that it has been a bit dead of itself.....never noticed that the ports are different! that could maybe be my prob slowwy??
72.7K members
