Corsa 1.4 Auto gearbox probloms
Results 1 to 6 of 6
Thread: Corsa 1.4 Auto gearbox probloms
    Sep 2005
    Northampton
    Corsa 1.4 Auto (98)
    I have just changed the automatic gearbox in my corsa, its a 1998 1.4 model, i still have the same problem as the old box, i can hear the engine revs drop as the box goes into gear, reverse or drive, but the car will not move, the small "S" light is flashing on the dashbord. Has anyone got any ideas that could point me in the right direction please. Thanks, Keith.
    Dom
    Dom is offline
    MIGWeb Moderator Dom's Avatar
    Sep 2001
    Northants
    Vectra VVT SRi
    Gearbox ecu ?
    Gearbox selector switch at the top of the box ?
    Enough fluid in the box ?
    Does it move if you use 1, 2 or 3 to pull off ?
    Sep 2005
    Northampton
    Corsa 1.4 Auto (98)
    Thread Starter
    It does have enough fluid, i got new fluid for the new box, it does not move in 1 2 3 or drive and reverse.
  5. Remove Advertisements
    Sep 2005
    Northampton
    Corsa 1.4 Auto (98)
    Thread Starter
    Sorry, it does not move in 1 2 3 drive and reverse,
  7. #5
    Dom
    Dom is offline
    Sep 2001
    Northants
    Vectra VVT SRi
    Worth seeing if you can get it to Vaux then to see if they can read out the gearbox fault codes on a Tech1/2 machine
  8. #6
    Sep 2005
    Northampton
    Corsa 1.4 Auto (98)
    Thread Starter
    Ok, thank u
