Please help. ECU, Loom OR Air flow
Results 1 to 8 of 8
Thread: Please help. ECU, Loom OR Air flow
    Jan 2002
    Rotherham
    nova 16v
    Unhappy Please help. ECU, Loom OR Air flow
    I am getting extremely frustrated, i have an engine, its a late redtop, i have a loom, it of a GTE, and i have an air flow meter with a pot screw.
    I have earthed pin 20 on the ECU cos i got no lambda sensor, and it makes the car run better, iit gets rid of the flat spot, but i cant adjust the mixture, CO readin is 7 +
    Is the FP, ECU meant for a cat? what could i do to get it running right anyone???
    The scrapper says he is going to get me a a air flow meter, ECU, and a manifold with sensor to remedy this, he dont know when tho!
    HEEEEEEEEELPP ME.
    Is there owt i can do???
    2.0l 16v nova nearly completed.
    Pics at www.geocities.com/davelad
    Jan 2002
    Rotherham
    nova 16v
    Thread Starter
    Sorry,
    Thanks
    Middlesex
    sideways
    It's too mix and match. Either get a Lambda sensored manifold, and the correct Air Flow meter to match your ECU, or get the ECU to match no lambda, and pot adjustable air flow meter.
    I hope you remember the original position of the air flow meter screw too, otherwise it'll be hassle when you do get it sorted.
    Brian Sidebotham.
  5. Remove Advertisements
    Jan 2002
    Rotherham
    nova 16v
    Thread Starter
    OOOOOh, your joking!!!
    Tried turning the screw till it stopped, but it didnt!!! lmao
    Will the ECU not run a lambda then???
    Just thought even tho it was an early one they might have made them compatible for future installation of a cat!
  7. #5
    Admin/show reporter Johnny A's Avatar
    Aug 2001
    Oxford
    Nova Estate
    Oh dear.
    I know someone who has got a spare l8 spec AMM if you need one.
    Vauxhall Nova Estate - Isuzu diesel, EPAS and it's an estate yo!
    Vauxhall Carlton V8 - Lexus 4.0 V8, US Cop car paint and light bar
    I used to be a real jerk but now i'm a people guy
  8. #6
    UK
    Cav turbo and XJR
    Did you check to see if there is that wire to the AMM. Brown/green was it ?
    is the ecu light coming on ?
  9. #7
    Jan 2002
    Rotherham
    nova 16v
    Thread Starter
    How much for the AFM???
    The loom has got that wire to the afm!
  10. #8
    Aug 2001
    Oxford
    Nova Estate
    I dunno, will ask when I can get in contact with him. Don't think they were too much though.
