using an early vw vr6 airflow meter /maf on a C20let ??
Results 1 to 10 of 10
Thread: using an early vw vr6 airflow meter /maf on a C20let ??
    Aug 2002
    Cape Town ;South Afr
    Opel Kadett 200tS
    Question using an early vw vr6 airflow meter /maf on a C20let ??
    Since my 200tS airflow meter /maf is broken i need to replace it.. finding a 'suitable' used one is almost impossible & a new airflow meter /maf is close to ₤300 from GM
    I was advised to use the an airflow meter /maf from an early vw vr6 (bosch 6-pin). Has any one done this.. Do I need to change any wires around on plug or does it a straight swop???
    Bosch part no for airflow meter /maf.
    0 280 213 012 - as found originally on tS
    0 280 213 024 - as found on C20LET is UK
    0 280 213 021 - as found on early VR6
    Thanks
    Boost-WP
    95 Opel Kadett 200ts
    197kw & 355nm
    Aug 2002
    Opel Kadett 200tS
    anyone
    Boost-WP
    197kw & 355nm
    Aug 2002
    Opel Kadett 200tS
    nobody done it yet
    Boost-WP
    197kw & 355nm
    MIGWeb User mind_crash's Avatar
    Jan 2005
    Market Harborough
    Project 200TS s
    i would think it should work normally........as in same resistance invonveld in the AFM...but i think that the way the thing reacts to the amount of air would differ from your car ie the spring on the flap in the AFM.......!!!! how the weather in capetown today...........i came from guateng dont spose you know someone with a VR6 and can test it
    I was the stig
    My new 180iE
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    The vr6 isnt a flap type,its an amm rather that afm. It should work,ive swaped them from vw to vw(different models)vw to audi and vw to bmw and they all worked.
    Jan 2005
    Market Harborough
    Project 200TS s
    how does it messure the air then??
    I was the stig
    My new 180iE
    Apr 2002
    Perth Scotland
    Audi A6 quattro 5cyl
    PM sent
    various vauxhall part. Breaking audi A4 1.8t mk1, S4 and S6. Pm
    Jan 2005
    Market Harborough
    Project 200TS s
    Quote Originally Posted by GSImad
    PM sent
    keeping it private are we lmao
    I was the stig
    My new 180iE
    Jul 2004
    Cyprus
    92 Calibra Turbo Ph2
    so does it work mate or not?
    1992 Calibra Turbo (Phase 2 since 23/04/2006)
    Jun 2009
    Georgia
    Re: using an early vw vr6 airflow meter /maf on a C20let ??
    Quote Originally Posted by mind_crash View Post
    help me plssss, this is work or not?
