mk3 astra hunting after changing water pump
Results 1 to 9 of 9
Thread: mk3 astra hunting after changing water pump
    Aug 2005
    Hi
    Can anyone help please.
    I have put a new water pump an a J reg(92) 1.4 astra and lined the little groove on the bottom pulley up with the little raised bit on the plastics and then lined the groove on the cam pulley straight up with the V cut out in the plastics and started the engine and it fires up and runs but the revs drop and then pick up every couple of seconds.
    Regards
    M9G
    Gagged
    Jan 2005
    Poole
    BMW M3 Ltd Ed
    Checked the timing marks since running it?
    ///MPOWER
    Aug 2005
    yeah
    I am right with the marks that I have set up arn't I.
    little groove on the bottom pulley with a little plastic sticky up bit on the lower plastic cover and then line up the groove on the cam pulley with the little V shaped notch cut out the top of the plastic that sits behind the cam pulley.
    Regards
    M9G
    Gagged
    Jan 2005
    Poole
    BMW M3 Ltd Ed
    Did you time the marks before removing old belt, to check?
    Sounds right though I think.
    What else have you removed in doing this, disturbed something?
    ///MPOWER
    Aug 2005
    i did line them up but had to take the pulleys off to get to the waterpump so the pulleys moved but re-aligned them when put back.
    I don't think i disturbed anything.
    I don't have a manual and wanted to be sure that the marks i am ligning up are correct
    M9G
    Jan 2005
    Nottingham
    Astra MK3 1.6 e
    Is the tensioner set right? The water pump will have to be turned to the right angle to make the tensioner line up with apointy bit in between two behind it if I remember correctly (sorry for vague description)
    Martin
    Aug 2005
    Quote Originally Posted by astra_marn
    Martin
    Went and bought a manual and saw about the pointy thing on the tensioner, all sorted now.
    Many thanks
    M9G
    Jan 2005
    Nottingham
    Astra MK3 1.6 e
    Cool, always good when people let us know things are sorted
    Cheers
    Martin
    Nov 2002
    Livingston
    tbh your very very lucky u didnt bend anything if it was cambelt tension that was causing the problem
