Jus got my engine running after rebuilding it completly
Its was starting fine and running fine
But today i took it out a wee run round block to see how it was going and it conked out![]()
Wouldnt start so towed her home and read Ecu fault codes
Please note ecu light was on b4 i conked out and has been since rebuilding her and i jus put it down to memory needing reset as it also needed this done last time i rebuilt it
With engine not starting i read codes with engine turned off and got
31 Engine RPM signal (crankshaft sensor) No signal
Which i though was fine as engine wasnt running so would show that but thought it strange this is all that came up
But try'd turning engine over and it fired up after about 10 turns and did so 3 times when i try again again so its not starting properly first of all
BUT
with engine going i now get
19 RPM signal (crankshaft sensor) Incorrect signal
and
117 Wastegate valve Low voltage (which i got last time we rebuilt engine and it was jus a broken wire on Amel valve which i have unplugged jus now so engine can run in without having to worry about 280 horse wanting to play![]()
SO WHATS YOUR OPINION'S (sp)
