got a clibra with a c20ne with a fuel leak on one of the pipe i know its under pressure can i cut out he bad and insert a rubber subsitute with ut it blowin off under pressure its at the tank end ta
Is it the metal pipe? If so, it's fine to cut out a small section and replace it with a piece of injection hose (not normal fuel hose) and a couple of jubilee clips.
