I think i have an oil leak from the rocker cover gasket? is this a common problem on the omega, is it a hard job to do should it be taken to vauxhall as i have read that the inlet manifold has to be taken off, the prob;em is that the oil is dripping onto the heat shield of the exhaust and as a consequence burning, does this sound like the rocker cover? cheers mat
