Cleaning out your idle control valve (20xe)
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 37
Thread: Cleaning out your idle control valve (20xe)
    Admin/show reporter Johnny A's Avatar
    Aug 2001
    Oxford
    Nova Estate
    Now I got the bugger off, I have been told to clean it up, how?? Obviously cleaning the electrical connections.
    But what about the rest, will spraying a load of carb cleaner down one of the pipes work??
    Vauxhall Nova Estate - Isuzu diesel, EPAS and it's an estate yo!
    Vauxhall Carlton V8 - Lexus 4.0 V8, US Cop car paint and light bar
    I used to be a real jerk but now i'm a people guy
    Jun 2001
    Cheltenhamshire
    saab 900 V6 SE LPG
    You can actually get these ultrasonically cleaned, but if you don't want to go to that expense, get some carb cleaner in there!
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    Yeh, but Luca charge 20/injector for ultra sonic cleaning.
    If its 20 for an ultrasonic clean to my idle valve I could rather have that. Nice and clean and some nice smooth idling me thinks.
  5. Remove Advertisements
    Northeast Kent
    you can hook up the two terminals to a car battery and the valve will open up fully, you can then flush the valve with carb cleaner.
    the only downside is that carb cleaner is hideously flammable, and connecting the valve to a battery makes a spark, oooops, wooooooooooooffff, aaaagghh me eyebrows.
  7. #5
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    Don't worry about that, I am more than stupid enough to try that odders
  8. #6
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    Yep, that stings. (just got some carb cleaner in my eye).
  9. #7
    Northeast Kent
    it smells beautiful though dont it.
  10. #8
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    Taste ain't too great though
  11. #9
    Jun 2001
    Cheltenhamshire
    saab 900 V6 SE LPG
    LOL
    You're meant to use it on the idle valve, not drink it!!!
  12. #10
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    oh crap, I knew I went outside for something!!
  13. #11
    Kent
    Haynes Roadster
    Good old Carb cleaner.
    Cleans, makes you high and stings quite nicely !
  14. #12
    May 2001
    Essex
    1983 Manta GTE
    better way to do it. but you need some tools.
    take off the valve but leave conected to the wires. set up a code reader onto the diagnostic terminal and set a pulsating test (cant remember the exact name for it at the mo). this will open and close the valve every 1 second. spray cleaner in there and it will be spotless...
    alternativly get a new one...
    ____________________/\____\o/______________________shark attack!!!
  15. #13
    Sep 2001
    Glasgow Area-ish
    EVO VI & GTE 16
    is it easy to get at on the 16v car? I know where it is I just havent had a good look at it.
    Never get an EGG credit card they do nothing to protect you if your card is subject to Fraud!!!!!!!!!!!!!!!!!!!
  16. #14
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    You have to get under the car, unscrew two jubilee clips and take off the power plug. Then it just drops out.
    I connected a 12V battery to mind and kept turning it on and off while spraying carb cleaner into it.
    Replace it?? You certainly know how to waste cash!!
  17. #15
    Sep 2001
    Glasgow Area-ish
    EVO VI & GTE 16
    cheers I will get that done as mine is on ramps at the mo while I sorted the exhaust clamp out.
  18. #16
    rgb
    rgb is offline
    Sep 2001
    Southampton - Hampsh
    17th Jan! :-)
    It is well over 100 for a new one from Vauxhall.... think its about 180.
  19. #17
    Northeast Kent
    i just sold mine for 20 quid, should have got in there mate
  20. #18
    Dec 2000
    durrington, wilts
    mine,mine,mine,mine!!!!!!
    good job i got yours actually Daz, coz mine went tits up after the engine swap!!!!!!!!
    Goatmuncher Inc.
    Probably the finest goat products in the world.....
  21. #19
    Northeast Kent
    all i got left is the inlet manifold now, sniff snifff, those were the days, when i was a nipper
  22. #20
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    hey calm down guys, no need to get all emotional on me!! Its only a bit dirty, it ain't broken yet!!
  23. #21
    near Glasgow....
    BMW 540i....
    HAHAHA, you should try it on the turbo..... Cant get to it from underneath due to t/x box and its a pain in the fecking arse to get at from the side.
    Do-able, just VERY fiddly.
    The Cav-Turbo Resource:
    Click Me
  24. #22
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    er, thanks for that one Richie, not that I have a Turbo.
  25. #23
    May 2001
    Essex
    1983 Manta GTE
    once you got em off a few times it gets easy, sight is no longer neccersary.
    when i said a new one, i meant a second hand new one, i got 2 spare sitting here. allways 1 if the current one goes wrong, which it has, twice...
  26. #24
    Aug 2001
    Oxford
    Nova Estate
    Thread Starter
    The reason I removed and cleaned it was to see if it made a difference to a hessitation problem I have at the moment.
  27. #25
    Nov 2000
    St. Asaph, N. Wales
    Nova, Audi, Landrover
    i just washed mine out with a full can of carb cleaner down the pipe to it with the engine running
    LEE69
