Whats the difference between the inlet manifold from a c16xe and a x16xe.
I've been told that the 'c' stands for the engine having a cat and the 'x' on the X16xe is because it has a cat and a egr valve??
Is this true and can i put a c16xe inlet manifold on my x16Xe. The reason i want to do this is because if the c16xe has not got an egr valve the inlet manifold will not have the egr ports messing up the inlet shape.
