Vauxhall Astra 2.0DTI Loss of power at 3000RPM
Results 1 to 10 of 10
Thread: Vauxhall Astra 2.0DTI Loss of power at 3000RPM
    Dec 2004
    Angry Vauxhall Astra 2.0DTI Loss of power at 3000RPM
    I have a Vauxhall Astra 2.0 DTI estate 2001 with 52000 miles on the clock. When on the motorway in 4th or 5th gear and the revs hit 3000RMP the ecu light comes on and there is an immediate loss of power. The light stays on until the engine is restarted, the power and the light then come back up. Could anyone throw a little light on the subject please. Many thanks.
    Mark
    May 2004
    Birmingham
    Vectra saloon 2.2sri
    Re: Vauxhall Astra 2.0DTI Loss of power at 3000RPM
    isnt that when the turbo kicks in ?
    SOTV KRO !!!!
    Dec 2004
    It could be...any ideas????
    worcs
    Lotus S2, Mk4 Astra CD
    Airflow sensor is a common fault - about 100 quid from Autovaux, so I'd check the fault code first.
    go on, don't be a wuss, just chmod 777 it
    Mar 2003
    Manchester
    Corsa C / RWD Nova
    Check oil level first - vacuum system to actuate egr valve / swirl and boost pressure solenoid valves all rely on vacuum being produced by the vac pump - which due to its design, relys on oil !!!
    Other than that - check none of the vac pipes/connectors have splits in them allowing a loss of vacuum
    Other than that - it probably down to oil contamination in the air flow meter as previously mentioned !!!
    Dec 2004
    Thanks for the replies, will try the remedies mentioned. Much appreciated.
    Sep 2003
    Redditch
    Corsa Sport 20XE
    my 54 plate 1.7cdti astra with 9k on the clock went through a phase of doing this also, vaux could fnot find anything wrong (no faults were found in ecu!), It hasent done it for about a month now so im just going to hope its magicly fixed itself.
    Nov 2000
    Liverpool, U.K.
    Mk3 Cav SRi 8v
    Dunno if this is worth anything but when I had one of those 2.0 16v DTi`s the turbo seemed to be there all the time, as in it didn`t wait for revs to pick up it was just there all the time from idle
    So, if you're scared half to death twice, does that mean you're dead??
    MSN -->>(c_montgomery_burns@msn.com)
    ...I don`t know a great deal about turbo`s...
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    We (the met) have a problem with these. As said check the vacuum hoses (especially the ones near the battery with the solenoid) Take of the plenum chamber (at front of engine) i bet it has a gooey gunk type residual, clean this up all is sorted. I bet you've given this diesel a hard life
    www.shonkyopels.de
    Dec 2004
    Talking Astra 2.00DTI Loss of power at 3000RPM
    It was the Maf sensor, changed it and wow!!! what a difference in performance. I did clean the maf thoroughly but it must have been faulty. Sorry for late reply.
