hi, i am quite a new member on here and am in need of some help. I fitted a cavy 130 engine in my b plate 1.3 sr at the weekend but cannot suss the ignition wiring! There is a plug coming off the ecu loom with 7 wires going into it. the bit that plugs into it has 8 wires coming from it. On the nova wiring loom there is only 2 wires which were connected to the coil after i took the dizzy off.(a black wire and a green wire) I tryed splicing these into the black and green wires on the plug from the ecu but no spark still. Any help would be great
