Oh, my X20XEV toothed belt broke down, and the worst happened - it didn't start after replacing the belt. Hopefully pistons are ok.
I don't have recources to repair the head nor buy a new one.
I have spare 18E head with manifold and injection system for my other car.
I have a plan to use this head on XEV.
I haven't found anything about this conversion yet.
I have an intrest for this project
For the budget (i will sell simtec 56.5 injection parts, manifolds, camshafts)
A bit crazy, but is it?
What would be the biggest restriction on my way?
I've thought through almost all parts.
The xev would have
* 18E head
* 18E manifolds
* LE2-Jetronic
* 18E alternator
* 18E ignition sys
The biggest problem would be compression ratio. Can you calculate/predict it for me? I have 2 cyl-heads 1mm skimmed and 2mm skimmed (10.4:1 & 12:1 on 1.8L). 10.4 head would have 11.6:1 if the 2.0L block has the same piston top etc. But i've heard, that 20XE-pistons raise CR compared to 20NE up to 1:1. Therefore CR would be 12.5:1.
What to do? Enlarge 18E combustion chamber? skim pistons ? 2 gaskets?
If the valves are bent, I dont think the pistons wont be too healthy either.
The x20xev has outputs for the inlet manifold switchover+ other stuff. You'll need to find a way rounnd that too, unless you're not using the x20xev ecu ?
I know a guy who had almost the same accident. The Only broken things were 2 exchaust valves & 2 valve guides (not pistons).
I won't be using this "8-runner-manifold".
Manifold, TB, fuelrails, fuel-pressure-regulator, ECU, injectors & all sensors would be from 18E Jetronic.
I think these yellow injectors are ok, if i raise the pressure. They produced 133bhp on my tuned 18E @2.5bar.
This conversion is more like XEV-block to 18E engine but with A/C, powersteering,transmisson and stuff.
I can machine this comb.chambers up to 6cc biger (each one) - which is more than 10% decrease in CR.
If i accomplish CR 11.3:1 with some mods for example, is it ok? I ask because i wont be using ignition system with knock sensor anymore , but mechanically adjustable distributor.
But i raised my 18E engines CR without a problem from 9.5 to 10.4:1.
I know a Corsa wich has c20xe witrh CR 14:1, but it wont run without toluen or similar additives. He only runs dragstirps (ET <14sec). But i will drive this car every day.
11 is the magic number?
Actually methanol is not the case. I wan't to run relatively cheap.
although technicalSpirit (ethanol) is here only 1pound per half a litre
eats hoses tho
i ran 10.summat:1 on an 18e, had to run high fuel pressure and additives to stop pinking
14.1 would see the pistons clear through the head...that been calculated correctly? 12:1 is about the highest you can ever go and thats not a pump fuel engine imo
eats hoses tho
Couldn't you get rid of pinking by adjusting the ignition?
It's funny, because i've heard pinking only once, and that were, when dizzy's spring got loose.
I don't know about that Corsa much. Sry.
Isnt the height of the comb.chamb. ca. 8-9mm so you can raise CR a lot more
no, theres no clearance really
pinking is pretty common really, i sorted it in the end, but had overskimmed the head in all reality, would have suited a nice pair of carbs tho
It can't be that bad.
If it runs ok with std 10.8:1 it must withstand some higher CR too.
I know this hi CR was possible also thanks to the XEV c.chamber but....
Isn't 10.8:1 @ -30C like 11.9:1 @ +20C? Because if power made in these conditions is equal, then peak pressure etc must be alike also.
hmm
Do i have to measure some how the chamber sizes to be sure? combustion chamber is the only thing i'm going to change, when watch from cylinder.
i replaced the head gasket a year ago, but can't remember how small that chamber was.
if 20NE head + c20xe block = 11.5:1
then 20NE head + x20xev <= 11.5 + (10.8-10.5) = 11.8:1
18E + X20XEV = 11.8/1.8x2.0 = 13.1:1 actually it's wrong.
Do you know the CR of 18E head on 20NE block? Then we can calculate.
comb chamber is quite big already, i concentrated on port and throat with mine, didnt manage to do much with the valve area tbh
2 gaskets, always better with 1 custom thick one, but yeah of course
or rebore and fit 20ne pistons? standard ne cr is 9.5:1 iirc, summat like that anyway
I think 20NE & 18E has the same fittings.
But my year 1997 xev has "new block" or smtg. It curved walls, A/C and powersteering fittings on block, which 18E doesn't have. Also dipstick has different place. 20NE wont help.
I've fitted FWD 18E inplace of RWD Kadett B 1.1L using Rekord 18S mountings transmission, dizzy and stuff - but this Astra actuallly isnt my big project, althogh i've got 100km/h in 8.1sec - pretty good for family Caravan. but its also my everyday ride - so i want to keep it cheap and simple.
So the block must stay.
My headwork looks nice (80 roller grit @2800RPM does it), but i havent tried it yet. I think it needs new seat angles to be got, because of rough handling of drill . I also skimmed it maybe too much (2mm).
80 quid is too expensive - but it may be a lot cheaper here in Estonia.
One option is to use C20XE head is out of budget, althogh it's cheaper than repairing or buying the ECO head.
My friend bought a good used 2.5V6 engine 320£, i'm not willing to pay even third of that. to get mine runnnnning.
