EGR valve
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 34
Thread: EGR valve
    MIGWeb User Scott G's Avatar
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    EGR valve
    Ok corsa is flashing up a EGR code, so i phoned autovaux for a price, 130 all in, which if its gonna fix the car, isnt to bad.
    However what exactly is the valve? What am I getting for my money?
    Plenty of scrap yards around here I could steal one off and try instead of splashing out on a new one, but I need to know what it looks like and if they are a generic part for different engines.
    Anyone got a picture of one to assist me?
    My ex Mk3 Astra - My Corsa Sport - Join MIG Club ONLINE Here!
    "A wise man know everything, a clever man knows everyone"
    Dec 2002
    Liverpool
    Vectra Estate
    Re: EGR valve
    I think most people clean it, it clogs up due to the exhaust gas passing through it.
    Never done it myself, just heard that a good clean usually solve the problem.
    The Novas are all gone now, just the Vectra estate left!
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Thread Starter
    Re: EGR valve
    Where is it?
    The car has only done 53K, I would be a bit upset if it had gone wrong so soon.
  5. Remove Advertisements
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    Re: EGR valve
    Im sure you can bypass it,await further info though.
  7. #5
    Oct 2004
    Asti - ITALY
    Corsa GSI - X16XE
    Re: EGR valve
    I have cleaned it...
    The valve (on a corsa 1.4/1.6 16v) is under the upper tract of the inlet manifold on the right (bonnet view). To access you need to remove the upper manifold and move away (or remove) the water expansion tank.
    I have cleaned the ducts from rust and have leaved the valve 2hr in gasoline, after i have cleaned it with a rag. After i have lubricated the steam with spray silicone grease.
    This as worked great for me (the error code is 3 month that not appear)...
  8. #6
    Oct 2004
    Asti - ITALY
    Corsa GSI - X16XE
    Re: EGR valve
    sorry, not gasoline... it italian is "gasolio", but in english???
  9. #7
    OllyHewitt
    Guest
    Re: EGR valve
    Quote Originally Posted by Scott G
    Where is it?
    It's the circular metal thing, infront of your rocker cover.
    You also have 'what looks like' an electronic alternator to the right of the rocker.
    There will be 2 vacuum pipes going to the valve itself.
    It helps get the Catalytic Converter get upto temperature quicker, thus making your car more fuel efficient
  10. #8
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Thread Starter
    Re: EGR valve
    Thats the one I was aiming for Olly, take that off and give it a clean out. Cant do any harm.
    the one behind the inlet manifold is some air sensor from what I have read.
  11. #9
    Oct 2004
    Asti - ITALY
    Corsa GSI - X16XE
    Re: EGR valve
    In my X16XE (and X14XE) i'm sure that the egr is under the intake manifold, near the expansion tank (Haynes manual )
  12. #10
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Thread Starter
    Re: EGR valve
    Controversial.
  13. #11
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Thread Starter
    Re: EGR valve
    Ignore the arrow, but others are saying its the silver thing at the bottom of the picture.
  14. #12
    Jan 2002
    Bedfordshire
    Corsa 1.6 & 1.6TB
    Re: EGR valve
    It is located on the inlet manifold
  15. #13
    Oct 2004
    Asti - ITALY
    Corsa GSI - X16XE
    Re: EGR valve
    Yellow arrow...
  16. #14
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Thread Starter
    Re: EGR valve
    Whats the other thing then?
  17. #15
    Oct 2004
    Asti - ITALY
    Corsa GSI - X16XE
    Re: EGR valve
    I think that you have pointed the fuel vapour valve...
  18. #16
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Thread Starter
    Re: EGR valve
    I see it now.
    hmm could be fun.
  19. #17
    May 2004
    Brum
    Veccy
    Re: EGR valve
    Hi,
    The silver thing at the front is the secondary air injection valve, the EGR valve is under the inlet manifold and is held on by 2 M8 allen head bolts, clean the plunger inside with some WD40 and a screwdriver to scrape away the crap
    HTH
    Baz
  20. #18
    Dec 2002
    Liverpool
    Vectra Estate
    Re: EGR valve
    Quote Originally Posted by masterx81
    Direct translation: gasolio = diesel oil
  21. #19
    Aug 2001
    Swindon, Wiltshire
    Astra J VXR/Ampera
    Re: EGR valve
    scott, ive got a couple of valves kicking around that u could try...
    PhilAstra@Hotmail.com
  22. #20
    Oct 2004
    Asti - ITALY
    Corsa GSI - X16XE
    Re: EGR valve
    Quote Originally Posted by danny_bellis
    Thanks
    Sometimes I do not trust the translation of google...
  23. #21
    bjr
    bjr is offline
    Jul 2003
    sittingbourne
    astravan
    Re: EGR valve
    Quote Originally Posted by OllyHewitt
    egr valve doesnt do that
    thats secondary air injection
    egr valve uses a small amount of exhaust gas injected into the cylinder to slow the burn time down a bit reducing toxic exhaust gases
  24. #22
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Thread Starter
    Re: EGR valve
    MAJOR headache to get into it, we played away with what we had but no use.
    Im calling vauxhall tomorrow to get it booked in.
    Handy. I fancied getting my arse violated.
  25. #23
    UK
    Cav turbo and XJR
    Re: EGR valve
    I know little about EGR but I think your looking for an electrical fault. Solonoid with 2 pipes and an electrical connector.
    I wouldn't have thought cleaning the pipes will turn the light off.
    Replacing it or checking the connector might
  26. #24
    bjr
    bjr is offline
    Jul 2003
    sittingbourne
    astravan
    Re: EGR valve
    Quote Originally Posted by Andy K
    your right
    my brothers astra had the same fault, dirty sticking valve had caused the small egr control solonoid to burn out causing the fault code
  27. #25
    Dec 2001
    Chelmsford, Essex,
    Astra1.8, Zaf1.8/1.9CDTI
    Re: EGR valve
    The ECU only checks for current flow.
    So long as the solenoid is OK and the connector/loom are OK, the ECU won't know the state of the EGR valve.
    The one on the Estate, is just hanging loose on the loom, with the EGR ports blanked.
  1. 08-09-2013, 05:04
  2. 22-02-2012, 19:59
  3. 10-01-2012, 22:16
  4. 08-09-2011, 09:06
  5. 23-03-2011, 08:19
  6. 18-02-2011, 19:50
  7. 22-12-2010, 23:23
  8. 14-08-2010, 19:39
  9. 06-07-2010, 21:19
  10. 08-05-2010, 06:19
  11. 07-05-2010, 00:25
  12. 05-04-2010, 21:25
  13. 13-03-2010, 01:11
  14. 12-02-2010, 00:14
  15. 28-12-2009, 09:21
  16. 29-10-2009, 12:46
  17. 22-06-2009, 11:32
  18. 18-06-2009, 18:57
  19. 17-06-2009, 11:48
  20. 15-06-2009, 13:17
  21. 13-06-2009, 22:44
  22. 13-06-2009, 21:48
  23. 08-04-2009, 16:53
  24. 05-04-2009, 12:51
  25. 30-03-2009, 20:49
  26. 03-02-2009, 18:40
  27. 02-01-2009, 20:01
  28. 29-12-2008, 06:42
  29. 26-12-2008, 21:48
  30. 07-12-2008, 18:33
  31. 06-12-2008, 17:52
  32. 06-12-2008, 17:27
  33. 29-10-2008, 08:40
  34. 20-09-2008, 07:06
  35. 07-06-2008, 21:04
  36. 28-04-2008, 13:14
  37. 16-04-2008, 19:11
  38. 04-04-2008, 18:35
  39. 30-03-2008, 10:51
  40. 30-03-2008, 02:06
  41. 16-10-2007, 18:16
  42. 11-08-2007, 15:50
  43. 08-06-2007, 11:13
