righty 99 corsa seatbelt clasp needs to be renewed looks like a T40 bolt holds it on.
Need to get another which model is compatible? Also doesn't have seat belt pre-tensioners or an airbag which for a 99 model is a bit shocking.
Last small VX seat I removed was a nova where you undone the U clamps and removed the clip so the seat could slide right off. How do i go about this on a corsa?
long time since doing a corsa, i may well be wronge, and mocked for the 25 years on here but, i seem to remember there the corsa seats slide too, a small alan key bolt and nut rings a bell, secoundly are sure that it dosnt have pre-tensioners? i was under the impression that all cars of that age had?
well got another pre-tensioner, sadly the corsa ones were all spent so a mk3 astra one it is then.
The corsa has had the pre-tensioner removed! The passenger side has it but the drivers side only has the rail there, thats why the clasp wasn't working then!
The astras cylinder though is held in via the seat anchor bolt so I will have to work around that, cable ties to the rescue me thinks.
