fitting pot type fidanza flywheel to a late c20xe and need opinions/ help on following:
1. On the block side of the flywheel, the bolts holding the clutch plate stand too proud and I have had to shear 2mm off each to ensure they clear sump/ block gasket. Has anyone else had this problem?
2. Should I use washers with ARP flywheel-to-crank bolts? The original doesn't, but these bolts seem to eat into the alloy.
3. Any idea on correct torque for these bolts?
